Unknown Wire 1974 1.8 L-Jet Double Relay |
jwilliamadams |
Jul 1 2006, 06:27 PM
Will Adams Group: Members Posts: 28 Joined: 1-May 05 From: San Luis Obispo, CA Member No.: 4,010 Region Association: None |
1974 1.8 L-Jet
There is a single yellow wire from the fuel injection double relay to the engine relay panel and it plugs into one of the terminals of the quad connector on the panel. See the attached picture. I think I have it plugged onto the correct terminal of the quad. Can someone with a 1.8 L-Jet take a look at their relay panel and see if their single yellow wire is plugged onto the same terminal as mine? Wiring diagram is useless. Is just indicates that the yellow plugs into the quad connector on the relay panel. It does not indicate which terminal. Thanks! |
Lo-Fi Version | Time is now: 16th May 2024 - 12:25 AM |
