Unknown Wire 1974 1.8 L-Jet Double Relay |
jwilliamadams |
Jul 1 2006, 06:27 PM
Will Adams Group: Members Posts: 28 Joined: 1-May 05 From: San Luis Obispo, CA Member No.: 4,010 Region Association: None |
1974 1.8 L-Jet
There is a single yellow wire from the fuel injection double relay to the engine relay panel and it plugs into one of the terminals of the quad connector on the panel. See the attached picture. I think I have it plugged onto the correct terminal of the quad. Can someone with a 1.8 L-Jet take a look at their relay panel and see if their single yellow wire is plugged onto the same terminal as mine? Wiring diagram is useless. Is just indicates that the yellow plugs into the quad connector on the relay panel. It does not indicate which terminal. Thanks! |
jwilliamadams |
Jul 1 2006, 07:05 PM
Thanks Grasshopper!
jd66921 |
Jul 1 2006, 07:15 PM
Member Group: Members Posts: 316 Joined: 9-January 06 From: Texas Member No.: 5,394 |
Thanks Grasshopper! Maybe someone can explain the wiring on a '75 1.8 to me then. I have a white wire coming out of the 12 pin connector bundle that connects to the four pin connector, but the next pin over. Also, I do not have a power supply relay, or a fuel pump relay. This does not seem right to me, but then I do not understand any of this. My fuel pump runs all the time, and does not shut off after a few seconds. Is this a fuel pump issue, or a relay issue? Grasshopper, anyone?? |
Lo-Fi Version | Time is now: 16th May 2024 - 01:01 PM |
