2 Pages V < 1 2
> Unknown Wire 1974 1.8 L-Jet Double Relay
jd66921
post Jul 3 2006, 11:31 AM
Post #21
My post a couple of replies ago was right on the money!!
Once I straightened out the fuel pump contact, the fuel pump operates
correctly. This morning I tried out the modified airflwo sensor, and the car
started. I'm still working on a few other problems, but I think I can do it now,
of course with the help of everyone here!!
I wonder if this will also fix the miss that I had. It might be related, as the car
would cut out momentarily on the way home.
I need to find a few more vacuum leaks, as the car will not start and will barely
idle without my finger in the airflow sensor to hold it open! I think it is the
oil breather line. I need to work on the cold start stuff as well. I don't know if
it is working right. It used to, when I first picked up the car. I also need to
figure out my #2 cylinder problem, but there's hope now!
It's been a long two months! I would NEVER have figured this out without the
help of everyone here. I'm actually surprised I found this at all!!
Thanks to everyone for your help!!
Jeff
ClayPerrine
post Jul 3 2006, 04:06 PM
Post #22
Make sure you replace the seals in the oil filler cap too. On an L-Jet car, they cause a vacuum leak that will prevent it from idling.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 19th July 2025 - 07:30 AM
