2 Pages V < 1 2
> Transmission, What fluid works best??
BigDBass
post Jul 3 2006, 08:55 PM
Post #21
Dumb Question Champion
So, hypothetically, say someone new to 914s wanted to check their transmission oil level, borrowed the right socket (what's that type of socket called?) and couldn't find the transmission drain plug even after looking at the pics in Clymmer and lack of pics in Haynes... where would he look? (IMG:style_emoticons/default/biggrin.gif)
Dr Evil
post Jul 3 2006, 09:06 PM
Post #22
Send me your transmission!
"someone" eh?
You need a 17mm 6 sided allen wrench or socket. Many have adapted bolt heads in various ways.
The drain is the lower plug and is on the right hand side. Above it is the fill and it is the same.
DO NOT REMOVE the drain plug before you have removed the fill plug. Why? Because you may not be able to remove the fill plug and then you will not be able to fill your tranny with any ease. Fill to the level of the fill plug with the car level.
Do you need pics? I can scrounge some up if no one else has some.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 16th November 2026 - 01:04 AM
