> No Spark...(76 2.0 FI)Shoot Me...PLEASE!
kskwpb
post Jul 2 2006, 12:57 PM
Well, here's a shocker....You guys were totally right on with my fuel pump nightmare, pulled the relay board, Big chunk missing under large three prong relay? Well I sodered the connector, busted out glue gun,filled in relay board....put it in...fuel pump purred like a kitten....now NO Spark @ plugs or when I pull wire from coil to distributor cap....It's like the ignition is turned off....Help me...PLEASE (IMG:style_emoticons/default/unsure.gif) Best Regards & CHEERS to all. Kevin
So.Cal.914
post Jul 2 2006, 01:51 PM
"...And it has a front trunk too."
Do you own a meter? If not try a hot wire from battery to heat ignition if still
no spark you know it is eather coil or points/ EI.
kskwpb
post Jul 2 2006, 02:03 PM
QUOTE(So.Cal.914 @ Jul 2 2006, 11:51 AM) *
What's a heat ignition?
- Lo-Fi Version Time is now: 2nd July 2026 - 07:21 AM
