atsealevel914 |
Member ![]() ![]() Group: Members Posts: 103 Joined: 31-January 04 From: Miami,FL Member No.: 1,618 ![]() |
What the heck is going on? (IMG:style_emoticons/default/poke.gif)
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
dunno...
go to your control panel and check what subscribtions you got running (you can turn them off) |
atsealevel914 |
dunno... go to your control panel and check what subscribtions you got running (you can turn them off) Thanks for the reply. I had already done what you said and there were only two topics im subscribed to that are supposed to be there. Im getting notified on almost every new topic that comes up continously its getting annoying. does anybody else know about this? Moderator? |
Jeroen |
in that case, you probably subscribed to a forum, instead of "loose" posts
go to "my controls" in the lefthand panel under "subscribtions" click on "view forums" unsubscribe as needed... |
atsealevel914 |
Jeroen |
yer welcome
lemme know if that doesn't fix the problem... |
Lo-Fi Version | Time is now: 16th July 2025 - 03:53 AM |
