big 4 engine specs, what to expect?, used motor in 550 spyder, potential? |
Dave Avery |
Oct 10 2003, 02:01 PM
Unregistered |
Hey all
sorry for the crosspost to shoptalk, but I thought you guys could shed some light on this too: I bought this motor used, and it's now in my 550. I'm not sure what to expect from it... I did speak with the mechanic, and he sounds very reputable. 103mm pistons, 75 mm Crank, SCAT connecting rods, Web Cam 86a, Web Cam lifters, H/D valve springs, heads ported and polished with 48mm x 38 mm valves, aluminum valve covers, all new bearings and gaskets, lightened the flywheel, dual Weber 44IDF carbs, Bosch 050 with points. I'm using a holley blue pump with a holley regulator, set to 3.5psi (gauge tapped) The engine runs very strong, and seems like it's all about 2-4K RPM. There is a stumble if I floor it, but it runs nicely at half throttle. Power drops sharply after said RPM, which leads me to think that either. 1) Weber 44IDF's are choking off high end 2) Timing is way off 3) Webers are way off 4) Porsche 901 has cruiser gearing 5) Gunk in the jets I would expect this engine to be at around 150-180hp, and in a 550 spyder (1300lbs without me) this thing should be a rocket. I'm pretty happy (esp. for the $2500 I paid for it) but it seems more like a tractor than a rocket (IMG:style_emoticons/default/wink.gif) So, two questions... 1) What should I expect from this motor powerband wise, and 2) any ideas on making it work better? This is actually the fun part, after a 3 year buildout (IMG:style_emoticons/default/smile.gif) Thanks, -DMA |
Lo-Fi Version | Time is now: 26th May 2024 - 07:01 AM |
