N 015.371.1, serrated lock washer |
Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
type47 |
Jul 10 2006, 10:33 AM
PET 501-00 #32 lock washer qty:16
lock washer used with CV bolts. this pix was copied from www.gowesty.com. commonly called a schnorr washer. another substitution: http://www.mcmaster.com/#standard-washers/=dknups 90895A030 stainless steel M8 another source: https://www.belmetric.com/metric-schnorr-wa...1l8gfe91p30l1t4 (I have seen a recommendation to NOT get the stainless washer because it's too soft http://dorkiphus.net/porsche/showthread.ph...6101&page=2 ) Attached image(s) |
JWest |
Nov 10 2006, 02:13 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Replacement available from McMaster-Carr
Part Number: 93501A030 Belleville Shape - Serrated Top and Bottom |
McMark |
Apr 23 2008, 05:15 PM
8mm ID
These are formed with a 'cone' shape. If your old ones are flat like a 'normal' washer then they will not hold as tight. I choose to treat these as a single use item. I throw them away and use new every time. |
IronHillRestorations |
Apr 23 2008, 07:42 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
(IMG:style_emoticons/default/agree.gif) With McMark
Lo-Fi Version | Time is now: 18th May 2024 - 09:05 AM |
