What I found out about my car today, First time looking at it after it was purchased |
poohsan |
Jul 14 2006, 10:23 PM
Newbie Group: Members Posts: 46 Joined: 10-July 06 From: Los Angeles Member No.: 6,409 |
Today was my first time really looking at the car after purchasing it. I have not seen the car all week and was feeling some buyer’s remorse. All of that changed today after I went through the car. It is actually better than I thought is would be. More things work than not. I am also confident that it is a keeper. (IMG:style_emoticons/default/piratenanner.gif)
Here is a run down of what occurred today. Items removed: Old center consul Floor mats After market pull-out radio harness and all related wiring Remains of an alarm system Run of wires from radio to trunk for non extant amp Run of wires to the battery for the non extant amp 3 spoke center caps on wheels Silly overly small steering wheel Dead fuses Things fixed: Passenger side outer door handle, door now opens Added a factory steering wheel Rear hood now latches tight Things I discovered: Window wipers do not work Fog lights my be spliced into head light wire harness Found some wires from wire harness in front trunk not connect to anything Wires near wiper motor not connected to anything 80% of the dash wiring is intact and works Passenger side head light does not illuminate when I switch on the Brights Body has less rust than I thought Rear bumper is compressed on passenger side from impact Rear end is sagging need new springs Emergency break button popped off. Speedometer was serviced at some time so mileage may be off. Speedometer works but cable is not spinning when I drive Will need all seals around Targa top, windows, door handles Hood release lever does not spring back and needs to be pushed into place No “E” in Porsche on my engine hood Rocker panels are cracked Rear view mirror is a goner All carpet and upholstery will need to go. Dash pad is a goner Have a short shifter that will need to be replaced with a stock one Passenger side window is chipped Good things: Starts on the first try Engine runs good Transmission shifts good except for downshifting into first while I am rolling Low rust Rims look like keepers for now Breaks work good If all goes well I could be driving it to work on Monday. |
Lo-Fi Version | Time is now: 16th May 2024 - 09:01 PM |
