GROUP BUY Programmable electronic fuel injection (, Is anyone interested in a SDS Group buy? |
Mark Henry |
Feb 27 2003, 02:21 PM
Programmable electronic fuel injection (PEFI)
Is anyone interested in a SDS PEFI GROUP BUY? Base system list is $785 or $1165 for the full meal deal (crank trigger ignition) for the 4-cylinder version.(full list price, not counting discount) Discount is 10% off for 2 systems and up to 25% off for 10 systems. So that could = the base 4 cylinder system for approximately $600* or about the price of a new MPS. *(Based on the basic system, no options with 10 people in the buy for a 25% discount, no shipping.) This is for the brain only, many options, you must check out their site and decide what you want/need. Will work on the stock engine and intake system to get you going. Then you can go hipo crazy (cam, TB’s, stroker, etc.) if you want. (I think with a few options $800. to $1000.+ is maybe a more realistic cost per system.) http://www.sdsefi.com/ The points I like about it are: you don’t need a laptop (which is good for me as I’m totally ‘puter stupid), the controller stays in the car, they will build it with a real CHT sender, they custom tailor the harness, the base system isn’t too expensive, info BBS, they have aircooled experience and the guy uses it on his own plane. A couple of bugs and a couple of 911’s are running this system, one 914 in progress. Check it out, sounds good to me, but if you’ve heard anything bad about them let me know. The only real negatives that I have heard so far is; the CPU isn’t waterproof and the 914 guy said that he was having trouble (stock fan) mounting the crank trigger. 6 cylinder version base price $ 815, full meal deal $1320. (full list price, not counting discount) 8 cylinder and Mazda 2 rotor systems also available. If anyone is interested shoot me an email. I’m thinking about buying at the end of April/May. mhenry69@sympatico.ca |
JeffBowlsby |
Mar 2 2003, 02:19 PM
914 Wiring Harnesses Group: Members Posts: 8,509 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
"The EM-4 ECU uses 4 connectors arranged on one side. The left plug is for injector drive wires and options. The DB25 connector is for sensor, ignition trigger wires and ECU power. The DB9, 2nd from the right, is for the Hall sensor connection and the far right DB9 is for the LCD programmer. Complete main wiring harness and injector harness are supplied, made to your custom specs if desired along with Hall sensor and LCD programmer cord. Standard main harnesses and injector drive harnesses are 6 feet long from ECU to most sensors, Hall sensor cables are 7 feet standard. Programmer cable from ECU to programmer is 6 feet. Please note that there will be a $30US/ $45CDN additional charge for custom length wiring harnesses as of Jan.1/03 and that custom harnesses will usually delay orders an additional day or so."
SDS apparently supplies 'standard' 6 foot long harnesses-what 'made to your specs' means is not clear. The photos show the injector harnesses without boots or casing, both of which are critical to long term performance of the system, but it wouold cost alot more for them to make it up. I would jump at the chance to make up the harness for this system...I can see how it would look sah-weet. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:06 PM |
