My new teener has a lot of over steer, Think I will start by adjusting the front swaybar |
Brad Roberts |
Jul 18 2006, 01:26 PM
This works in the cross weights, but all the stocker 914's running around on bad rear springs have a LOT more rear grip than front grip (IMG:style_emoticons/default/biggrin.gif)
Of course, we all know that the cross weights are more important than the front to rear bias. B |
Joe Ricard |
Jul 18 2006, 02:56 PM
easy to fix throttle lift over steer.
DON'T LIFT THE GAS PEDAL IN A TURN if you start sliding the rear on the street stop what you are doing and get your head checked "you are nuts" if you get the rear stepping out on a AX course mash the gas so as to transfer weight to the rear wheels. it will stick. |
Lo-Fi Version | Time is now: 7th June 2024 - 10:40 AM |
