924 wiper switch, Will this Mod work in a 73 |
Stieve |
Jul 17 2006, 03:39 PM
Senior Member Group: Members Posts: 587 Joined: 6-May 06 From: Sacramento Member No.: 5,996 |
I have a 73 914 and want to update to the 924 electric wash system, I did it years ago in a 75 I had, will this work in a 73.
Aaron Cox |
Jul 17 2006, 03:41 PM
good luck... i got stiffed on the last 3 i purchased....
you need a 76-79 setup. let me know if you find one please. (i have an extra vdo pump in trade (IMG:style_emoticons/default/smile.gif) ).... AA |
Stieve |
Jul 17 2006, 03:45 PM
good luck... i got stiffed on the last 3 i purchased.... you need a 76-79 setup. let me know if you find one please. (i have an extra vdo pump in trade (IMG:style_emoticons/default/smile.gif) ).... AA I have the turn signal and wiper switch, and the pump, can I drop it in and connect the washer leads? Which ones are they? |
Aaron Cox |
Jul 17 2006, 03:47 PM
mr 924 haynes manual can tell you...
there should be ONE extra wire i believe.... that goes to the hot on the pump i think.... not quite sure... but this is on my todo list.... Have an extra 924 wiper switch? |
Stieve |
Jul 17 2006, 08:20 PM
Stieve |
Jul 17 2006, 10:08 PM
I found mine on eBay $24 for both turn signal and wiper
eg914 |
Jul 17 2006, 11:07 PM
Member Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
There is a thread somewhere with directions for this. Boils down to two extra wires, and the plastic piece on the new switch is too wide to fit in the steering column. Just remove the white plastic piece, put on the old one, and route the two extra wires from the pump switch down the column. I did this, but haven't put in the pump yet. The wiper part works fine (better than the one it replaced with only low speed!).
Aaron Cox |
Jul 17 2006, 11:09 PM
10 bucks if you find me a 924 wiper switch for under 35 bucks....
AZ914 |
Jul 18 2006, 09:43 AM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
Qarl wrote a tech article about this. It is on the bird board tech section.
Aaron Cox |
Jul 18 2006, 12:35 PM
http://www.pelicanparts.com/techarticles/9...tric_washer.htm
nicely done karl... find me a switch PLEASE!!! |
Allan |
Jul 18 2006, 12:53 PM
10 bucks if you find me a 924 wiper switch for under 35 bucks.... 924 Wiper Switch $27.30 Pay up.... (IMG:style_emoticons/default/biggrin.gif) |
Aaron Cox |
Jul 18 2006, 01:03 PM
wrong one....
thats a late model |
Stieve |
Jul 18 2006, 01:20 PM
Nice try though
Aaron Cox |
Jul 18 2006, 01:49 PM
76-79 part...
Allan |
Jul 18 2006, 01:54 PM
Description says '76 - '85. (IMG:style_emoticons/default/confused24.gif)
Aaron Cox |
Jul 18 2006, 01:57 PM
it lies!
Aaron Cox |
Jul 18 2006, 02:13 PM
i read that the VW 74-79 beetle switch MAY BE the same...
(IMG:http://www2.cip1.com/photos/VWC-111-953-519-G-2.jpg) but there are 4 and 5 wire varieties... how many does a 914 or 924 switch have??? and why does it STILL have tube hookups!?!?!?!? VW part: VWC-111-953-519-G |
bd1308 |
Jul 18 2006, 03:12 PM
I just took out all of the plastic tube stuff and attached a microswitch with the lever thing onto the switch itself.
works. b |
Stieve |
Jul 18 2006, 03:20 PM
you need a 924 ONLY 76-79
AZ914 |
Jul 18 2006, 05:56 PM
I got one at home that I haven't installed.. I'll snap a picture tonight.
Lo-Fi Version | Time is now: 17th May 2024 - 05:52 PM |
