901 shift rod alignment tool, save a little money.... |
PRS914-6 |
Jul 18 2006, 12:46 AM
I posted this on my progress thread but I thought I would do it here for a better search in the future. While rebuilding my 901, I needed a shift rod tool and didn't have one. I used a spare 901 (911) intermediate plate. All you need is an old race for the main shaft (from inside the case) that fits perfectly in the intermediate plate. The pinion shaft needs a spacer that I made in the lathe but you could use about anything as long as it was spaced equally all the way around. You can see the spacer at the end of the arrow. It worked great. $0
(IMG:http://www.sayegh.org/Paul/914/914pics/Img_0201.jpg) |
Red-Beard |
Jul 18 2006, 05:37 AM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
If you can find an old/bad case, you can make a perfect one with a Sawzall
Lo-Fi Version | Time is now: 20th May 2024 - 03:51 PM |
