Thinking about A/C, Its getting hot... |
Andyrew |
Jul 20 2006, 12:47 AM
So... Im thinking about a portable way to make an A/C system for my v8...
But. here are the limitations. I will not rob any hp by putting on a compressor. (more belts to possibly fail) The unit has to be completely removable The unit cant cost more than 150 in parts or 200 premade. Here are a couple of options that im thinking. along with pro's/cons ICE BOX Build a box that holds ice packs and ice, throw some fans, some switches, ect, and get some ice cold air coming at me. Pro's. Cheap, 20 bucks in airplane fans, metal/wood is cheep, Plastic sealing, Mesh for the ice to sit on, switches, and an lighter plug.. Cons. Sealing it will be a problem, Drain off might cause some issues, Ice will only last an hour max, ice packs will be maybe 2 hours cold. PREMADE Couple of company's are out there making beverage coolers and warmers.. http://www.amazon.com/gp/product/B00005R2M...&n=15684181 http://www.globalsources.com/manufacturers/Car-Cooler.html Even http://www.kooleraire.com/index.htm Pro's.. No fab... Cons.. Not for cooling the car, but food Thermoelectric... Now it gets interesting... I read some stuff, and noticed most of the coolers are using this thermo electric thing... Now how can I make this into something useful? If I understand it right, one polarity heats up one plate, and one polarity freezes another plate. So.. http://cgi.ebay.com/Thermoelectric-Peltier...1QQcmdZViewItem http://cgi.ebay.com/Gigantic-62mm-350-Watt...1QQcmdZViewItem If I used them instead of ice... I might get some pretty darn good cooling output?!? But what about power usage? Those little things I just dont understand... Anyone want to help me and tell me if im dreaming? Thanks Andrew |
maf914 |
Jul 20 2006, 07:49 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Cheap cooling? (IMG:style_emoticons/default/idea.gif)
Years ago JC Whitney sold cylindrical evaporative coolers (or swamp cooler) that mounted in the car window and hung in the airstream. When the car was moving air would pass through a wet element and be cooled by evaporation and then enter the car. Evaporative coolers work best in areas with low humidity, the lower the better. As humidity increases the evaporation rate decreases. Maybe you could find one somewhere? (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 2nd May 2024 - 02:53 AM |
