check this out weird noises, sound like its in the tunnel !! |
kpex914 |
Jul 21 2006, 11:32 PM
Newbie Group: Members Posts: 48 Joined: 29-March 06 From: Fresno,Cali Member No.: 5,792 Region Association: None |
i have a '73 1.7 with 133,000 miles. (dont no if it makes a difference) when im goin about 40 the i down shift and have the clutch in and hit the throttle i hear a rattle the sounds like it comes from the tunnel. could it be the shift ram, or a cable of some sort? i dont really no what it is.
(IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/WTF.gif) |
Jul 22 2006, 03:14 AM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i have a '73 1.7 with 133,000 miles. (dont no if it makes a difference) when im goin about 40 the i down shift and have the clutch in and hit the throttle i hear a rattle the sounds like it comes from the tunnel. could it be the shift ram, or a cable of some sort? i dont really no what it is. (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/WTF.gif) clutch tube has broken lose inside the center tunnel. very common. do a search here for a fix (you'll need a welder for that) ... and while you're in there, check and make sure it hasn't also broken lose on the rear firewall. if so, more welding ... (IMG:style_emoticons/default/welder.gif) Andy |
Lo-Fi Version | Time is now: 18th May 2024 - 03:26 AM |
