Sporatic at 2400-2800rpms |
HotWat |
Jul 29 2006, 09:30 PM
Newbie Group: Members Posts: 7 Joined: 16-March 05 From: Los Gatos, CA Member No.: 3,771 |
My '75 2.0 developed a hesitation/sputtering between 2400 - 2800 rpms which is driving me crazy. The car was serviced a few months ago (valves, etc). I have electronic ignition. Any ideas. Thanks.
Rand |
Jul 29 2006, 11:42 PM
If it only sputters in that rpm range, and clears back up above, it makes me think of a worn TPS (throttle position sensor - the gadget mounted on the side of the throttle-body).
They contacts wear... especially in the most-used range. At any rate, learn more about it here: http://members.rennlist.com/pbanders/ |
Bleyseng |
Jul 30 2006, 08:29 AM
To check the TPS just unplug it. Its the big 5 prong thingy on the Throtte body.
If it goes away when you unplug it and drive it then you know the tps is dirty or dead. (IMG:style_emoticons/default/agree.gif) If that doesn't fix it, check for a sticking advance plate in the dizzy. |
HotWat |
Jul 30 2006, 07:38 PM
To check the TPS just unplug it. Its the big 5 prong thingy on the Throtte body. If it goes away when you unplug it and drive it then you know the tps is dirty or dead. (IMG:style_emoticons/default/agree.gif) If that doesn't fix it, check for a sticking advance plate in the dizzy. Unplugged the TPS and made no difference. What the heck is the dizzy. |
Bleyseng |
Jul 30 2006, 09:24 PM
dizzy= distributor
check the advance plate for smooth operation as rust/nolube will make it stick |
Dr. Roger |
Aug 6 2006, 03:17 PM
so what was the problem?
has it been resolved? how? inquiring minds want to know. =-) |
rmital |
Aug 6 2006, 03:32 PM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
Dr. Roger |
Aug 6 2006, 03:53 PM
this guy does a good job of rebuilding a 010 distributor. great pics.
yours is not like this one but some of the details are the same. just a matter of do you want to pull your distributor for a rebuild or pull the contact plate to get at the advance weight assembly for cleaning and lubing. good luck. (IMG:style_emoticons/default/burnout.gif) |
rmital |
Aug 6 2006, 05:53 PM
Dr. Roger |
Aug 6 2006, 05:56 PM
Lo-Fi Version | Time is now: 12th May 2024 - 04:10 AM |
