Axle Bearing, Is this Normal? |
t collins |
Aug 3 2006, 05:27 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
I just replaced my rear axle bearings and after pressing the hubs back into the bearings, I noticed if you hold the hub and try to move it side to side you can feel some movement in the bearing. Is this normal when the stub axle is not in place?
(IMG:style_emoticons/default/unsure.gif) |
Cap'n Krusty |
Aug 3 2006, 05:32 PM
I just replaced my rear axle bearings and after pressing the hubs back into the bearings, I noticed if you hold the hub and try to move it side to side you can feel some movement in the bearing. Is this normal when the stub axle is not in place? (IMG:style_emoticons/default/unsure.gif) Yes. Once the axle is in and torqued, the freeplay will be gone. The Cap'n |
t collins |
Aug 3 2006, 05:43 PM
I just replaced my rear axle bearings and after pressing the hubs back into the bearings, I noticed if you hold the hub and try to move it side to side you can feel some movement in the bearing. Is this normal when the stub axle is not in place? (IMG:style_emoticons/default/unsure.gif) Yes. Once the axle is in and torqued, the freeplay will be gone. The Cap'n Thanks Cap'n That makes me feel better! |
Lo-Fi Version | Time is now: 15th May 2024 - 08:26 PM |
