Ut-Oh, Guys check your drains |
J P Stein |
Oct 19 2003, 10:55 AM
Something to try before you start cutting out metal.
For pin holes like those, stick an appropraite size nail in the hole and see if you can weld it in. If the base material doesn't disappear (too thin) you've saved a lot of time and effort. Grind semi-flush. BTDT. BTW, that looks like a sound pad deal rather than drains. |
Joe.D |
Oct 19 2003, 11:51 AM
MCMLXXIII MCCM Group: Members Posts: 132 Joined: 16-June 03 From: Southern Maine Member No.: 830 |
Also, look inside the tunnel. My car has a similar problem due to a long-term leaking rear window that the p.o. ignored. The water also found its way into the tunnel. As a result, I found a huge quantity of rust flakes in there. (IMG:style_emoticons/default/icon8.gif)
Joe |
rhodyguy |
Oct 19 2003, 12:50 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
just for fun look down the grill at the fresh air box drains some time.
kevin |
TheCabinetmaker |
Oct 19 2003, 12:53 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Don't forget the drain holes under the headlights.
Bleyseng |
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Just for fun, take out the fresh air box!
Geoff |
rhodyguy |
Oct 19 2003, 12:57 PM
and weld one of these on. that's what i'm going to do!
kevin Attached image(s) |
TheCabinetmaker |
Oct 19 2003, 01:04 PM
Geoff, removing the fresh air box is not "fun".
Oct 19 2003, 04:01 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(DNHunt @ Oct 19 2003, 07:11 AM) Are there any solvents that will remove the residual adhesive left over from the tar crap? brake cleaner ... buy a case. Andy |
Oct 19 2003, 04:04 PM
QUOTE(seanery @ Oct 19 2003, 07:17 AM) I think Andy's car started out as a short winter-type project! actually, it was a "quick-fix", one weekend, clutch replacement ... turned out to be more than a 1 1/2 years. (IMG:style_emoticons/default/cool.gif) Andy |
redshift |
Oct 19 2003, 06:21 PM
QUOTE(boxstr @ Oct 19 2003, 11:53 AM) Dave If you are going to all of the trouble to drop the motor and pull the pedals and interior, why not do the job right and not half assed. Have the areas that show signs of rust media blasted and start with the best surfaces that you can. It will also help to find any other areas that you might not find by scraping. CCLINBLASTVILLE And so begins one mans journey... LMAO! (IMG:style_emoticons/default/smile.gif) M |
redshift |
Oct 19 2003, 06:23 PM
QUOTE(rhodyguy @ Oct 19 2003, 02:50 PM) just for fun look down the grill at the fresh air box drains some time. kevin SHUT UP! SHUT UP!!! SHUT UP!!! M |
DNHunt |
Oct 20 2003, 06:02 AM
Got the pans cleaned up. Paint thinner, acetone and lots of elbow grease. Not a fun weekend. Joe was right about some rust in the center tunnel.
DNHunt |
Oct 20 2003, 06:04 AM
No more tar or adhesive
Lo-Fi Version | Time is now: 9th June 2024 - 01:35 PM |
