Rear brake caliper rebuild Question, Can't figure out exactly how to tear down |
Mikey914 |
Aug 24 2006, 08:26 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Well I've got all of the easy part done. Actually the P/O tried to rebuild and the leak appears to be from the e brake actuator. How do I get this thing apart? the only thing left to do is remove the plug, but I didn't want to do it unless I have to.
The piston in this side is stuck in, I tried to pry lightly, but didn't want to put too much pressure on it incase there's something I might break. If anyone has any reference material the Haynes manual glosses right over this. Any help would be apreciated Attached image(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 10:06 PM |
