BLING! New 944/911 Axles, done and ready to be installed ... |
SirAndy |
Aug 25 2006, 07:44 PM
Resident German Group: Admin Posts: 41,656 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
it's been a while since i started this project. i had all the parts, but i was waiting for the right time to redo the complete rear suspension ...
yesterday, i went up to McMark's and we took out the old trailing arms and axles and shocks and prepared my new trailing arms and the axles. McMark finished the job today, and now i have: - new (unbend) trailing arms - new mueller roller bearings - new koni adjustable shocks - new axles with brand new 944 CVs (IMG:style_emoticons/default/smilie_pokal.gif) Andy PS: for the axles, i used, tranny to wheel: 915 (911, '75 - '79) coarse spline 6-bolt 100mm outputshafts -> 944 100mm CV -> modified 914 axle shaft -> 944 100mm CV -> 911 ('75 - '79) 6-bolt 100mm stub axle -> 911 ('69 - '73?) hub = real 5-lug! on top, the stock 914 axle, bottom, the new axle using 944 and 911 parts: and installed: |
SirAndy |
Aug 25 2006, 08:08 PM
the main benefits of doing this, IMHO:
- 944 CVs are still readily available brand new for reasonable prices. - 944 CVs are slightly bigger and wider than stock 914 CVs. - real 5-lug hubs instead of redrilled 914 hubs. (IMG:style_emoticons/default/smile.gif) Andy |
pek771 |
Aug 25 2006, 08:15 PM
Member Group: Members Posts: 273 Joined: 23-November 05 From: Conover, NC Member No.: 5,175 Region Association: None |
Nice work, Andy!
What did the mods to the axle shaft consist of? Pat |
Aaron Cox |
Aug 25 2006, 08:26 PM
not andy,
but you have to turn off a "bump/lip" on each end of the shaft where the stock dust boot sat iirc |
Chris Pincetich |
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
(IMG:style_emoticons/default/drooley.gif)
I think you will see the yellow through your wheels. sweet. Looks pretty fast on those jackstands! (IMG:style_emoticons/default/beerchug.gif) |
McMark |
Aug 25 2006, 09:03 PM
not andy, but you have to turn off a "bump/lip" on each end of the shaft where the stock dust boot sat iirc Nope. The 944 CVs are wider, so they need more room on the axle splines. (IMG:http://www.914world.com/bbs2/uploads/post-11-1123464006.jpg) |
Aaron Cox |
Aug 25 2006, 09:04 PM
not andy, but you have to turn off a "bump/lip" on each end of the shaft where the stock dust boot sat iirc Nope. The 944 CVs are wider, so they need more room on the axle splines. (IMG:http://www.914world.com/bbs2/uploads/post-11-1123464006.jpg) ahh yeah. i lied. LOL. that makes it mo betta |
fiid |
Aug 25 2006, 09:20 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
OMG. That's delicious.
John |
That is exactly what I did to 914-6 axle shafts to make 911 CV joints fit on them
Attached image(s) |
Eddie914 |
Aug 25 2006, 09:29 PM
Unregistered |
What model and year did the stub axle and outputshafts come from?
Where is the 100mm measured on the stub axle? I have one large four bolt stub axle and one six bolt. Not sure or the origin. The outputshafts I have are from an '86 915 and are also four bolt. Thanks Eddie |
SirAndy |
Aug 25 2006, 09:44 PM
What model and year did the stub axle and outputshafts come from? 915 output flanges and 911 stub axle came from a mid to late '70s 911 (~'75 - '79) and the hubs came from a early 911 (~'69 - '73?) ... 100mm is the dia. of the CV, so the flages and stubbies fit a 100mm CV ... (IMG:style_emoticons/default/smile.gif) Andy PS: and yes, stubbies and flanges and CV's are all 6-bolt ... |
jonwatts |
Aug 25 2006, 09:45 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
Andy, your avatar looks weird. Did you have some work done?
Oh, and cool suspension stuffs. |
SirAndy |
Aug 25 2006, 09:49 PM
Andy, your avatar looks weird. Did you have some work done? yeah, i spent about an hour in front of two mirrors with a clipper and razor blades trying to get the hawk straight and centered ... (IMG:style_emoticons/default/biggrin.gif) not perfect but gud enough for me ... (IMG:style_emoticons/default/aktion035.gif) Andy |
Mueller |
Aug 26 2006, 12:43 AM
it's been a while since i started this project. i had all the parts, but i was waiting for the right time to redo the complete rear suspension ... yesterday, i went up to McMark's and we took out the old trailing arms and axles and shocks and prepared my new trailing arms and the axles. McMark finished the job today, and now i have: - new (unbend) trailing arms - new mueller roller bearings - new koni adjustable shocks - new axles with brand new 944 CVs (IMG:style_emoticons/default/smilie_pokal.gif) Andy PS: for the axles, i used, tranny to wheel: 915(911) coarse spline 6-bolt 100mm outputshafts -> 944 100mm CV -> modified 914 axle shaft -> you're welcome (IMG:style_emoticons/default/smile.gif) 944 100mm CV -> 911 6-bolt 100mm stub axle -> 911 hub (real 5-lug!) on top, the stock 914 axle, bottom, the new axle using 944 and 911 parts: and installed: If you decide to sell those other parts, I think those spacers I made for you will need to be trimmed down a bit hieght wise.... |
So.Cal.914 |
Aug 26 2006, 12:48 AM
Kind of look like Sting when he was young, like in Quadraphenia, but without the
mohawk. I like the upgrades, looks bada$$. |
McMark |
Aug 26 2006, 01:08 AM
Actually, Mike they were about 0.25mm too short. Completely usable (IMHO), but visibly short. Not your fault, mostly Andy's. We need to buy that guy a digital caliper. (IMG:style_emoticons/default/smile.gif)
barrym |
Aug 16 2016, 02:34 AM
Member Group: Members Posts: 88 Joined: 12-October 14 From: Australia Member No.: 18,008 Region Association: None |
dragging up the old posts here ... which 944 cv joint did you use ? 944 s2 turbo ? are they all the same ?
thanks |
SirAndy |
Aug 16 2016, 03:01 AM
dragging up the old posts here ... which 944 cv joint did you use ? 944 s2 turbo ? are they all the same ? No turbo, just yer plain old 944 ... (IMG:style_emoticons/default/smile.gif) |
Cracker |
Aug 16 2016, 06:22 AM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Very nice Andy. Have you had a failure in the past or was this a proactive move on your part?
Tony |
SirAndy |
Aug 16 2016, 12:02 PM
Very nice Andy. Have you had a failure in the past or was this a proactive move on your part? I wanted real 5-lug in the rear, not re-drilled hubs. The slightly larger CVs were an added bonus. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 25th May 2024 - 05:52 AM |
