PolyBronze Bushing Install and other modifications., Lightweight V8 |
Mike T |
Sep 1 2006, 04:23 PM
can't 'member Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 |
After a dismal performance plagued by random oversteer at my last AX I decided to that continuing to use the car in it's current state made no sense. I have been accumulating a bunch of suspension pieces and fiberglass body parts and decided that there was no time like the present to get to work.
This was the car on July 16th; Attached image(s) |
Mike T |
Sep 1 2006, 06:03 PM
I repaired the bent nose by cutting away all the sheetmetal affected by the lousy repair job. With the front end sheetmetal cut away I needed to reinforce the front end.
I added bars from the existing angled tubing to the mounting area of the front suspension crossmember. I attached them to 1/8" steel plates to spread the load. I added a crossbar to stiffen the front of the torsion bar mounts. |
Lo-Fi Version | Time is now: 19th May 2024 - 09:56 PM |
