PolyBronze Bushing Install and other modifications., Lightweight V8 |
Mike T |
Sep 1 2006, 04:23 PM
can't 'member Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 |
After a dismal performance plagued by random oversteer at my last AX I decided to that continuing to use the car in it's current state made no sense. I have been accumulating a bunch of suspension pieces and fiberglass body parts and decided that there was no time like the present to get to work.
This was the car on July 16th; Attached image(s) |
Mike T |
Oct 12 2006, 11:24 AM
Another update on the work I did to my car.
I used the MADONE.NET ebay scales and they work pretty well. Fairly easy to set up but it takes a while to get them positioned just right. Chassis setup and adjustment is a little slow because you have to crunch your own numbers. I did my car in about 3 hrs and found them to be very repeatable. I bought the system with rollers on the frames that are supposed to allow the suspension to settle out any binding. I took 7 readings and the total weight reading varied by 2%. I consider that acceptable. I got the cross weights to 50.1% and couldn't fiddle them any closer. I'm going to redo the car to see if the results are repeatable. Should I make a thread when I do? With pictures? Anybody interested? Oh, by the way: After all the cutting and fiberglass body parts the total weight with fuel was 1820 lbs without driver. 56% rear weight, 49% left weight. Not bad for a V8 car with cast iron heads. Mike T |
Lo-Fi Version | Time is now: 19th May 2024 - 11:06 PM |
