> PolyBronze Bushing Install and other modifications., Lightweight V8
Mike T
post Sep 1 2006, 04:23 PM
Post #21
can't 'member
After a dismal performance plagued by random oversteer at my last AX I decided to that continuing to use the car in it's current state made no sense. I have been accumulating a bunch of suspension pieces and fiberglass body parts and decided that there was no time like the present to get to work.
This was the car on July 16th;
Mike T   PolyBronze Bushing Install and other modifications.   Sep 1 2006, 04:23 PM
Mike T   I began with the Bushing install. PolyBronze bush...   Sep 1 2006, 04:36 PM
Mike T   The PolyBronze Front Bushings come with 3 thicknes...   Sep 1 2006, 04:38 PM
Mike T   Here I'm using a .001" and a .002" s...   Sep 1 2006, 04:41 PM
Mike T   The finished installation. I let it set up overni...   Sep 1 2006, 04:47 PM
Mike T   When I removed the rear trailing arms I found this...   Sep 1 2006, 04:51 PM
Mike T   The trailing arm and all the parts to install the ...   Sep 1 2006, 05:01 PM
Mike T   Measure over 15/16", drill straight and you n...   Sep 1 2006, 05:31 PM
Mike T   I moved on to the chassis work. A few years ago I ...   Sep 1 2006, 05:45 PM
Mike T   With the rear tail light panel cut away along with...   Sep 1 2006, 05:50 PM
Mike T   I repaired the bent nose by cutting away all the s...   Sep 1 2006, 06:03 PM
Mike T   I replaced the entire front fender because it had ...   Sep 1 2006, 06:20 PM
Mike T   Here are the Weltmeister Polygraphite bushings I t...   Sep 1 2006, 06:38 PM
J P Stein   I'm prolly movin' to E Mod. Glad you doan ...   Sep 1 2006, 06:45 PM
trekkor   Thanks for posting. Glad to see a project moving f...   Sep 1 2006, 07:21 PM
URY914   Great thread and great job, Tim. Your front trun...   Sep 1 2006, 08:03 PM
Mike T   Last Wednesday I bought a set of the lever arm sty...   Sep 12 2006, 06:36 PM
914forme   :popcorn: Let us know!!!!   Sep 13 2006, 08:21 AM
Mike T   Just an update on my project. I received the scale...   Oct 3 2006, 05:22 PM
Mike T   Another update on the work I did to my car. I us...   Oct 12 2006, 11:24 AM
URY914   1820! What a PIG! :lol: But I suppose a V...   Oct 12 2006, 12:05 PM
Mike T   I know, I know... I was sort of dissapointed with ...   Oct 12 2006, 05:23 PM
URY914   I hear ya about the driver's weight. :( I dr...   Oct 12 2006, 08:55 PM
Rough_Rider   So Mike, What the skinny on those scales? Are they...   Oct 13 2006, 04:43 PM
Mike T   I think they work pretty well. Easy to use. Strong...   Oct 13 2006, 07:41 PM
914forme   You could allways change your block, Donovanmakes ...   Oct 13 2006, 08:32 PM
Mike T   I intended to put pics of the scales and weighing ...   Nov 6 2006, 07:36 AM
URY914
- Lo-Fi Version Time is now: 2nd April 2026 - 07:22 PM
