Lifts for home, Need more space in my garage |
jrmole |
Sep 13 2006, 11:02 PM
Torque is cool! Group: Members Posts: 93 Joined: 5-September 05 From: Los Angeles, CA area Member No.: 4,752 |
Howdy,
I have a 1950's house with what the realtor called a 2 car garage. Two 914s maybe, but only if people climbed over the doors. I would love to have seen two 1950's Fords in there :-) Into this tight space, my 914 will soon have to share with a stable-mate. When I was in junior high my father and I did a frame-off restoration of his 1953 MG TD. That was a (cough) few years ago and it is time to do it again. Since my son is soon to be in junior high, my father decided it was time to pass on tradition. Since I can't go sideways, it is time to think about going vertical with my 10 foot ceiling. I am looking for recommendations or experiences with light-duty four post lifts for home use. Since I live in earthquake country, I am not interested the the two post lifts (too tragic to imagine). Help! My wife has pointed out that I am going to go from a 30 year old German car to a 60 year old British car so the logical next step will be a 90 year old Italian car. Hmmmm.... Pictures of my toys below ... Attached image(s) |
URY914 |
Sep 14 2006, 07:18 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,578 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Go to this site and look around. They have different sections like we have here and also do a search for lifts. The subject comes up all the time. There is also a section on product reviews that will have some info. Good luck.
http://www.garagejournal.com/forum/ |
JmuRiz |
Sep 14 2006, 08:13 AM
914 Guru Group: Members Posts: 5,426 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I'd be sure to get an ALI/ETL Certified Lift, probably a 4-post and bolt it down (being in earthquake zone). The ones from Rotary's Revolution line look nice (what I'll probably get), also the Bend Pak. Good idea going up, 10' is plenty high clearance for those cars. |
mskala |
Sep 14 2006, 10:17 AM
10 feet for the common four-post lifts is enough for a 914 and a 'normal-size'
car stacked. I have about 9'5" but sometimes I want to go higher I take the roof off the 914 to go between the rafters. The common four-post does not need to be bolted down, and if I was in an earthquake zone I would much rather not bolt it. Think heavy item on top not connected to earth, posts would shift a bit on the floor, but if they were bolted down then you have a giant moment arm throwing your car around. |
Ferg |
Sep 14 2006, 10:29 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
I'm happy with my bend pac, it's a older model, but does the job, plus it's made in the usa, and parts are available should I need them. My ceiling is just shy of 11ft and works well with my two cars. I did need to raise the rails on my garage door closer to the ceiling so that when the door goes up, it still clears the car that's in the air...
Ferg (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
GTeener |
Sep 14 2006, 11:15 AM
914 Girl Group: Members Posts: 2,348 Joined: 25-June 04 From: SillyCon Valley Member No.: 2,249 Region Association: Northern California |
Ah, if money were no object (IMG:style_emoticons/default/biggrin.gif)
This would be so cool to have! http://hardingsteel.com/st24c.htm Attached image(s) |
jrmole |
Sep 14 2006, 09:10 PM
Thanks for all the suggestions.
One thing I am interested in is experience with installation support (especially unloading). I live on a really steep street. I once watched a forklift almost flip over when they turned slightly down hill with several cases of slate tile (IMG:style_emoticons/default/ohmy.gif) I really do not want to deal with a 1,500 pound lift. Thanks. |
JoeSharp |
Sep 14 2006, 11:13 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
jr, don't be affraid of the 2 post type. I saw a news clip of a garage that had been blown away, house and all. A Pontiac Grand Am was still on the lift with the house and garage gone.
Joe |
LowGT |
Sep 15 2006, 02:43 AM
1.8 and Proud! Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
Since I can't go sideways, Sideways worked for me for a while. I made people envious because I said I had a 3 car garage, however many people told be just because I could fit 3 cars in there didn't mean it was a 3 car garage. (IMG:style_emoticons/default/biggrin.gif) (IMG:http://www.lowgt.com/001/sort/cocoon.jpg) |
Ferg |
Sep 15 2006, 08:46 AM
I bought my lift slightly used, so It had to be taken apart transported and put back together. I hired a local installer to do the whole job, best 700 bucks I spent. I'd imagine that since yours is just set up, it would be much less complicated...
Ferg Thanks for all the suggestions. One thing I am interested in is experience with installation support (especially unloading). I live on a really steep street. I once watched a forklift almost flip over when they turned slightly down hill with several cases of slate tile (IMG:style_emoticons/default/ohmy.gif) I really do not want to deal with a 1,500 pound lift. Thanks. |
gopack |
Sep 15 2006, 09:03 AM
CHEESEHEAD in CA, MARK Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
this looks like a good deal! can't guess at the quality, but at 7000 lbs, should be WAY over engineered for a 914!
ebay lift |
Two914s |
Sep 15 2006, 09:16 AM
Member Group: Members Posts: 59 Joined: 22-September 03 From: Atlanta, GA Member No.: 1,184 |
I have a scissors lift that I LOVE but it doesnt really make any more room for other cars...
Joe Bob |
Sep 15 2006, 09:32 AM
I have a four poster....pisses off the neighbors to no end....
GTeener |
Sep 15 2006, 10:30 AM
I have a four poster....pisses off the neighbors to no end.... (IMG:style_emoticons/default/confused24.gif) Why? Is it in the driveway? Are you ruining their view? Wouldn't they be more pissed off if your cars were parked on the street in front of their house? |
GTeener |
Sep 15 2006, 10:34 AM
What is the minimum garage ceiling height to stack 2 cars with a parking lift?
JmuRiz |
Sep 15 2006, 10:48 AM
Probably pissed because that means more cars and more wrenching at home (impact wrech at midnight, hahaha).
Here's the height calculator from Revolution: http://www.revolutionlifts.com/Ceiling.asp |
Joe Bob |
Sep 15 2006, 10:54 AM
9 feet is absolute minimum and you can only stack small cars....
As to why it pisses off my neighbors....well the short story.... They called the City on my cars out front, so I asked the City if I could jump the curb put them in back....sure, so I cleaned up some mud that slid onto my property from the City proprety behind me....I live under a reservoir.....the neighbors bitched ABOUT THAT.... City hits me with an order to build an engineered wall to hold THEIR FARGIN dirt....OK, so I build a wall and a garage.....the neighbors bitch about THAT......so to really piss them off I put the lift in and I can get three cars in it now.... If they woulda shut the fuck up the garage wouldn't have been in their line of sight....I wrench on my cars and fuck up their view....I also do my refrigerator repair guy impression with a good moon in between....I used to have a jacuzzi up there too.... Got lemons? Build a garage and let yer dickwad neighbors cry like an onion...or something like that.... When I bought this house it was a derelict...like me. Ask Howie...it's quite nice now. Last house on a quiet street then a buncha yuppie DINKs moved in on newly subdivided lots above me....then try to take over the 'hood.....weeeelll guess what, "Homie doan play that game".... |
Aaron Cox |
Sep 15 2006, 10:56 AM
shoot them mike (IMG:style_emoticons/default/smile.gif)
mskala |
Sep 15 2006, 10:58 AM
What is the minimum garage ceiling height to stack 2 cars with a parking lift? It's going to be different with different height cars. Add the height of both cars, then add 8 to 10 inches. There are blocks on each post which are maybe 6 inches apart, and you need 2" of room to get over each block before the ratchet will grab it when you lower. Official height of 914 is 48" but many of us with slightly lowered cars and low profile tires are in the 45" area. |
jrmole |
Sep 15 2006, 11:02 AM
this looks like a good deal! can't guess at the quality, but at 7000 lbs, should be WAY over engineered for a 914! ebay lift Who said the 914 was going up top? When my 914 sees rubber on pavement again, it will be my daily driver (famous last words). The MG will be my weekend car and end up on the top. That said, 7,000 pounds is over kill for an MG too! Thanks for the link, I'll check it out. |
Lo-Fi Version | Time is now: 14th May 2024 - 08:34 PM |
