Carbon Fiber Front Clip, For sale |
groot |
Sep 20 2006, 10:52 AM
Dis member Group: Members Posts: 894 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
Okay, several people have asked about getting these front clips... here's the breakdown:
Front Clip Option 1 -Opaque gelcoat finish (ready to paint) made mostly of fiberglass, with some carbon for strength -Please select grey, white or black -Cost $490 plus $50 for tooling recovery* Front Clip Option 2 -Vacuum infused, clear finish made of 3 layers (6K, 11.4oz twill weave carbon, 1/8" core material for infustion, and carbon/kevlar hybrid twill -Cost $785 plus $50 for tooling recovery* Splitter Option (not required and can be mounted to other front clips, provided they have a level mounting surface) -Carbon fiber, leading edge is reinforced with extra layers of carbon fiber -Reduces ride height clearance, splitter's overall thickness is slightly over 3/8", (.390") (on my car this splitter sits 2" from the ground, while the front donuts are 3.5" from the ground) -Care should be taken to mount this as level as possible for maximum benefit -Cost $280 Shipping-required for all options (IMG:style_emoticons/default/wink.gif) -Figure between $80 and $180 for shipping using FEDEX Freight, must be shipped to a loading dock or can be picked up at a FEDEX Freight facility Timing -Please allow 2 weeks for construction -Orders can start IMMEDIATELY * Tooling recovery-This cost is meant to recover part of the money that I used to initiate this project including: purchasing the original air dam, shipping, constructing the tool and constructing the mold Place the orders through me and I'll work with Mike Cudahy of Prototype Composites to get you the parts. Here's a pic of the clip and splitter installed on my car: |
Trekkor |
Sep 20 2006, 12:00 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
brant |
Sep 20 2006, 02:00 PM
914 Wizard Group: Members Posts: 11,618 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I like the new paint Kevin.
the car looks amazing! whats the new weight this year? brant |
groot |
Sep 20 2006, 04:13 PM
Thanks, Brant... it's come a long way....
I'm at 1850 with driver... so I have to run ballast. |
brant |
Sep 20 2006, 10:48 PM
Thats awesome Kevin!
good job! brant |
nebreitling |
Sep 20 2006, 11:05 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
that car is exceptionally hot.
hars914 |
Sep 21 2006, 05:21 AM
Member Group: Members Posts: 114 Joined: 6-January 03 Member No.: 94 |
How is it mounted?? Does it have brackets molded in or is it dzus fastened
groot |
Sep 21 2006, 05:48 AM
The clip is only the shell, so one must devise their own mounting scheme.
I bolted mine throught the 916 Oil cooler opening on the front and then some brackets hold the back end of the splitter... allowing me to adjust the angle of the splitter as required. |
groot |
Sep 21 2006, 06:11 AM
Contact information....
e-mail or PM is the best way for the initial contact... so I keep track of all of this. My schedule can get hectic, so bare with me please. Ask any questions you want here so everyone can see what's discussed. I apologize for charging the "tooling recovery fee" but I did shell out over $2000 to be able to make this happen.... and I'm not that charitable (or rich). (IMG:style_emoticons/default/ohmy.gif) If this turns out okay and I don't lose my shirt, there may be other things we could develop in this fashion. |
Brad Roberts |
Sep 21 2006, 05:17 PM
Thanks Kevin (IMG:style_emoticons/default/clap56.gif)
You have done a top notch job on producing this piece for the 914 market. Your car looks GREAT!! Keep up the good work. Maybe one day we can throw some sponsorship your way. B |
mbdoc |
Dec 3 2006, 12:33 PM
Newbie Group: Members Posts: 24 Joined: 2-December 06 From: Lake Arrowhead CA Member No.: 7,298 |
Kevin,
Are you still offering the front clip in carbon fibre. What is delivery time and shipping costs to CA Thanks in advance. Adrian |
groot |
Dec 3 2006, 02:09 PM
Yes, they are....
The part should take only a few weeks to make and ship, depending on Mike's workload.... shipping and handling to So Cal could run $150-200. |
mbdoc |
Dec 3 2006, 03:35 PM
Yes, they are.... The part should take only a few weeks to make and ship, depending on Mike's workload.... shipping and handling to So Cal could run $150-200. Thanks I will place an order after the new year. Also if I may, I'm new to the 914's and am installing the bilstein coil overs in front. It seems as the top shock towers look weak as though it may rip out under extended hard loads. Do you know of any mods to strenghten this area. Adrian |
groot |
Dec 3 2006, 05:43 PM
It seems as the top shock towers look weak as though it may rip out under extended hard loads. Do you know of any mods to strenghten this area. Adrian The stock upper bearing does a good job of distributing the load. I have never seen this as a failure... but having said that, many people add camber plates.... might be a good idea to ask this in the "Paddock" forum to see what others are up to. |
Eric_Shea |
Dec 3 2006, 08:09 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
mbdoc |
Dec 4 2006, 11:23 AM
It seems as the top shock towers look weak as though it may rip out under extended hard loads. Do you know of any mods to strenghten this area. Adrian The stock upper bearing does a good job of distributing the load. I have never seen this as a failure... but having said that, many people add camber plates.... might be a good idea to ask this in the "Paddock" forum to see what others are up to. Kevin, I don't mean to be stupid but you say front clip and splitter. Please define. I was taught front clip meaing from windshield forward. Not sure of your term splitter. I'm interested in only the front bumper assembly complete as shown in your pic with the Sube in the background. Thanks Adrian |
michaelt55 |
Dec 6 2006, 05:54 PM
Graduate of Life's experiences Group: Members Posts: 438 Joined: 2-September 06 From: Richmond, Texas Member No.: 6,753 Region Association: None |
thats one gorgeous piece of carbon fiber....
any chance of getting some sort of stock mounting for it bonded into it? Michael |
groot |
Dec 7 2006, 10:02 AM
Good questions....
Really the part is a combination of a bumper and an air dam.... really a fascia in my world, but that may not be the term most people are familiar with. I'm only referring to it as a clip to make sure people understand it's not just a bumper shell. The splitter is a flat plate-like part that attaches to the bottom of the fascia to clean up the airflow underneath the car. You see them on a lot of newer race cars. This part is really a "race only" addition to the basic fascia due to the lack of ground clearance. It would be very difficult to live with this on the street. As far as stock mounting points..... I'm leaving that up to the buyer to figure out. Most of these cars are different and the uses of these parts will be different. For example... I made my mounts strong and adjustable for rake angle but easily removable because I take it off to get the car on the trailer. |
Tobra |
Jan 10 2007, 10:55 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
A thing of beauty.
how about front and rear decklids? or a top out of carbon fiber, that would also be pretty cool |
michaelt55 |
Jan 11 2007, 12:54 PM
Lo-Fi Version | Time is now: 2nd May 2024 - 11:35 PM |
