914 Transaxle Question |
914ev |
Sep 21 2006, 08:32 PM
Newbie Group: Members Posts: 8 Joined: 1-September 06 From: Phoenix, AZ Member No.: 6,748 |
Newbie starting out on a 914 project and have found a '71 roller without engine or tranny.
Will any 914 transaxle fit the '71, and do I need to worry about whether it's a side or tail shift configuration? -- Leon |
So.Cal.914 |
Sep 21 2006, 08:37 PM
Yes it will fit. A 71 came with a tail shift but you can convert it to sideshift and
the sideshift will give you more precise shifting. |
GeorgeRud |
Sep 21 2006, 08:38 PM
The cars before 1973 came with a tail shifter, and that would be the easiest to fit. However, the side shift transaxle is preferrable, and as long as all the parts from the shift knob to the tranaxle are replaced, the sideshift transmission and linkage can be updated into an early chassis car. Only one bushing needs to be specially ordered that is not a Porsche part (at the firewall where the shif rod comes trough the firewall)
Good Luck and enjoy your new toy! (IMG:style_emoticons/default/welcome.png) |
bugsy0 |
Sep 23 2006, 09:36 PM
Member Group: Members Posts: 191 Joined: 26-July 06 Member No.: 6,508 Region Association: None |
Don't forget the engine mount (cross bar). I believe that is specific to the side shifter, since the shift rod passes _through_ it. You would need a side shifter engine mount.
Dr Evil |
Sep 23 2006, 10:34 PM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Yes, these parts differ from side to tail shifter:
- Stick shift: Tail = ball and cup, side = blade coupling - Coupler to shift rod in center tunnel - Shift rod from fire wall to tranny - Fire wall bushing - Engine mounjt bar - Engine mounts from engine to bar - Bar mounts on body It seems like a lot, but you can get most parts for low $$ and free in many cases. It is not hard to convert (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 07:19 AM |
