Oil cooler venting on a 914 6, stays under 210 |
Heeltoe914 |
Sep 21 2006, 11:54 PM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
Seems to work well. I vented out of the fender. If I still need exit air I can add a little Turbo fan. But 210 temp puching 4500rpms for 10 min up hill in 4th is good for me.
My car is a euro car and did not have rubber plugs to push out in front, So I only cut open three plugs from the front section. Attached image(s) |
Joe Bob |
Sep 22 2006, 12:00 AM
Are you running a thermostat?
I was already to install mine and opened the box and the dumb asses sent me a -10AN thermostat....I have all -12AN stuff......SHIT!!!! I was thinking that since it warms up so qucikly that I could get away w/o one..... |
Heeltoe914 |
Sep 22 2006, 12:03 AM
Yes I run the Throutman that has a real 911 type thermostat.
You can but the stat is a much safer way to go. |
thesey914 |
Sep 22 2006, 03:40 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
This is without doubt the *sexiest* 914-6 I have ever seen.
Heeltoe914 |
Sep 22 2006, 01:26 PM
Thanks it came out better than I had planed. It has brakes and supension to match the eng,
jhadler |
Sep 22 2006, 02:15 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
I really like the venting location. Subtle, and I would expect at least as effective as holes on the inner wall of the fender well.
Can we see a pic of the front? Where did you route the oil lines? -Josh2 |
Lo-Fi Version | Time is now: 21st May 2024 - 08:41 PM |
