"Change" high-impedance injectors to low-impedance without a, want to use different injectors on my L-Jet... |
Mueller |
Sep 22 2006, 12:04 AM
I have a spare set of 19-lb Ford injectors that are ~15 ohms....
The L-Jet uses low-impedance injectors (approx same flow ratings) with the use of ballast resistors to bump up the impedance from 3 ohms to 9 ohms. Can I knock down the resistance of the 15 ohm injectors to 9 ohms without any ill affects? If I knock down the impedance, will they still flow 19-lbs at the same fuel pressure as before?? Hope the question makes some sense... thanks, Mike |
Lo-Fi Version | Time is now: 3rd June 2024 - 11:23 AM |
