> which 6 cyl engines are best for conversion, heard some models are not as good
2teeners
post Jan 5 2003, 12:41 PM
Which engines are the best 6 cylinders. It seems I read somewhere that mid 70's models were lacking in durability. What was it and is there a fix now? And as far as value, which would be the best.
Paul (IMG:style_emoticons/default/ohmy.gif)
krk
post Jan 5 2003, 02:19 PM
This post of mine will be of limited value. (this is, of course, in sharp contrast with my other posts:) Bruce Anderson's 911 book is a great reference for the various generations of P-6's, including strengths, weaknesses, fixes for weaknesses, etc. Lots of grotty details. Borrow or buy one.
Actual choice will depend on what you want to do and your budget (duh). Popular choice these days seems to be the 3.2, but Brad and others will chime in with real data. I've never done a conversion, so I'm just parroting info I've picked up from others.
kim.
mskala
post Jan 5 2003, 02:49 PM
R
From reading Bruce's book and from seeing posts on various boards, it seems to me like every variant has known problems, minor on some years, major on others. But people have figured out the fixes for them and there is decades of history for proof. If you are going to have an engine to put in a 914, you can fix the problems before you put it in. Then you can worry about other things.
Mark S.
'70 914-6 known problem is lack of power (IMG:style_emoticons/default/smile.gif)
Gint
post Jan 5 2003, 03:53 PM
Mike Ginter
Brad will correct me if necessary, but I believe the main complaint about the mid 70's years motors (2.7 and such), were the fact that they were smogged and catalytic converter'd to death (slow constant heat).
J P Stein
post Jan 5 2003, 09:08 PM
Irrelevant old fart
This question doesn't have an easy answer.
Much depends of what you are gonna do with the car......and, of course, how much treasure you can steal form the family budget.
In my case, the original conversion cost about $6600 of which $2400 went towards the motor ...a solid 2.4L T...130/140 hp. All the parts were new, cept the motor, and you can see that it was less than half the budget.
When one steps over the 170hp mark, an external cooler is a good idea......Brad doesn't agree with that, but WHF does he know? (IMG:style_emoticons/default/blink.gif) Tack on bout 800/1000 for a good set up there.
To keep this short, if I had it to do again, I would go with a carbed, but otherwise stock 3.0L..... 200 hp or so, with room for growth. Budget here would be 4500/6000. If you're not into "growth" stick with CIS and save 1500 or so.
Brad Roberts
post Jan 7 2003, 01:22 AM
914 Freak!
Here is how I approach this:
Nothing under a 3.0. Simple.
You will see core engines (2.0-2.7) for cheap.. there is a reason. For what it would cost you to rebuild a 2.0-2.7 you could have bought a low mileage 3.0-3.2. I feel JP's case was pretty rare. He found a decent engine with good parts (under 3.0) I have access to a running 3.0 engine right now for 1500$ Complete. It has 80k miles on it and 2 broken head studs. I would pull it apart and fix the studs/re-ring it (maybe 800$ with gaskets and such)
You really should buy the Bruce Anderson book. Dont buy or even look at a 6cyl engine for your car until you read this book.
B
campbellcj
post Jan 7 2003, 02:26 AM
I can't Re Member
I agree with what you guys are saying re. the 3.0-3.2 engines as the "sweet spot".
Unless you are doing track stuff, and that puts you into a classification with guys spending $50K-100K on their cars and you are on a "budget".
In that case the 2.0-2.7 sizing (depending what fits in your class and what you have access to) starts to look pretty darn good.
For a street conversion, no question, go with a strong 3.0 or 3.2 injected donor and don't look back. You will have the bulletproof motor of the 80's 911's with about 800lbs less car to haul around.
thesey914
post Jan 7 2003, 02:32 AM
Did a search for the Bruce Anderson book and got "Tantra For Gay Men" as a result!!!! Guess it's a different author by the same name (IMG:style_emoticons/default/biggrin.gif)
Do you recommend this book ( not the gay tantric one!!) as an engine rebuild manual or is it more tailored for the 911 buyer?
I am looking at a couple of 911 motors but they will most likely need a bit of refreshing so a bit of reference literature will be a great help
Brad Roberts
post Jan 7 2003, 02:54 AM
914 Freak!
Umm.. I used Google and it came up number 2 on the list.
http://www.911handbook.com/
Bruces book('s) has the best 911 engine coverage of any book. It does have 911 body styles and changes.. but its 80% engine/tranny/suspension which all fits under you 914 (except the rear suspension). You cant go wrong. If you order it from Bruce.. tell him Brad Roberts sent you. I consider us pretty good friends.
Oh.. it is not a rebuild book. Bruce and Jerry Woods teach a engine rebuild class. I doubt they will write a book about it. What Bruces book will do: It will tell you exactly what to look for in an engine...and what the issues where along with engine codes.
B
J P Stein
post Jan 7 2003, 04:30 AM
Irrelevant old fart
The only problem with a 3.0L+ motor is if you wanna go play at the SCCA autocrosses. What class are you in?....got me.
F prepared is limited to 2.8L with a 914.
Now if I could find a 3.0L 76/77 Carrera or 75/77 (?) 3.0 turbo case, I would build a new motor.....cheep,too....well, relativly.
I gots a plan. (IMG:style_emoticons/default/blink.gif)
Andersons book is (or should be ) required reading for anyone considering a 911 engine purchase. I've read it cover to cover ....more than once.
Jeroen
post Jan 7 2003, 07:48 AM
Region Association: Europe
Hey JP,
That's just what I got: a 3.0 Carrera engine (IMG:style_emoticons/default/biggrin.gif)
It's still missing the crank and cams though
(it's still apart) but the heads have been rebuild
If I'm not mistaking the crank of my 2.4 should fit/be the same
Still have to check what cams are on my 2.4 to now if they'll work with the 3.0 and webbers
Cheers,
Jeroen
J P Stein
post Jan 7 2003, 12:19 PM
Irrelevant old fart
Jeroen [/QUOTE]
>If I'm not mistaking the crank of my 2.4 should fit/be the >same
If I'm not mistaking, you're right (IMG:style_emoticons/default/tongue.gif)
Jeroen
post Jan 7 2003, 02:55 PM
Hey JP,
I guess we have a common goal (IMG:style_emoticons/default/biggrin.gif)
Cheers,
Jeroen
thesey914
post Jan 18 2003, 05:03 AM
Just received Bruce Anderson's book through the post this morning. Looks very detailed....well recommended, thanks.
seanery
post Jan 18 2003, 09:16 AM
waiting to rebuild whitey!
thesey914,
I like your avatar, very nice!
thesey914
post Jan 18 2003, 06:37 PM
Thanks (IMG:style_emoticons/default/beerchug.gif)
Brad Roberts
post Jan 18 2003, 11:26 PM
914 Freak!
I didnt realize you are located in the UK.
Your avatar is cool.. but something is missing (its not on a car) lol
B
Crawf
post Jan 20 2003, 09:36 AM
Hello,
Another fourteener from the UK here, I thought I'd take the opportunity to drop an e-mail to say what a useful website this is. I'm sure I'll be posting a few questions shortly.
The Sey - I didn't know you were contemplating a six conversion, did you source the Bruce Anderson book locally?
Crawf
Dave_Darling
post Jan 21 2003, 05:16 PM
914 Idiot
All B's points are true--but still, I like the idea of the earlier motor in the 914. The 2.4 "S" motor, to me, seems a terriffic choice. (Maybe carb'ed for simplicity over MFI.)
The early motors are lighter, and the swap is a little simpler. (Mostly the fact that you use an early 911 flywheel, instead of a more-expensive "converting" flywheel like on the 3.0+ cars.) And using a 70's-vintage motor in the 70's-vintage 914 seems "right" somehow.
Then again, if it were me I might just jump to 3.2 liters and run the stock Motronic FI. That way I wouldn't have to deal with those "black magic" carburetor thingies. (IMG:style_emoticons/default/wink.gif)
--DD
campbellcj
post Jan 21 2003, 06:29 PM
I can't Re Member
QUOTE(Dave_Darling @ Jan 21 2003, 03:16 PM)
Dave - I have to admit that the moment I decided I HAD to get a sixer was the first time I hitched a ride at the track in a well-prepped factory -6 with a 2.4S engine. I think the car was carbed and running open pipes or maybe supertrapps. It seemed like a great match with the narrowbody car on Hoosiers. I fell in love instantly.
- Lo-Fi Version Time is now: 18th July 2025 - 07:49 PM
