Tuesday, 23 September 2025
> which 6 cyl engines are best for conversion, heard some models are not as good
2teeners
post Jan 5 2003, 12:41 PM
Post #21
Which engines are the best 6 cylinders. It seems I read somewhere that mid 70's models were lacking in durability. What was it and is there a fix now? And as far as value, which would be the best.
Paul (IMG:style_emoticons/default/ohmy.gif)
2teeners   which 6 cyl engines are best for conversion   Jan 5 2003, 12:41 PM
krk   This post of mine will be of limited value. (this ...   Jan 5 2003, 02:19 PM
mskala   From reading Bruce's book and from seeing post...   Jan 5 2003, 02:49 PM
Gint   Brad will correct me if necessary, but I believe t...   Jan 5 2003, 03:53 PM
J P Stein   This question doesn't have an easy answer. Muc...   Jan 5 2003, 09:08 PM
Brad Roberts   Here is how I approach this: Nothing under a 3.0....   Jan 7 2003, 01:22 AM
campbellcj   I agree with what you guys are saying re. the 3.0-...   Jan 7 2003, 02:26 AM
thesey914   Did a search for the Bruce Anderson book and got "...   Jan 7 2003, 02:32 AM
Brad Roberts   Umm.. I used Google and it came up number 2 on the...   Jan 7 2003, 02:54 AM
J P Stein   The only problem with a 3.0L+ motor is if you wann...   Jan 7 2003, 04:30 AM
Jeroen   Hey JP, That's just what I got: a 3.0 Carrera...   Jan 7 2003, 07:48 AM
J P Stein   Jeroen [/QUOTE] >If I'm not mistaking the cran...   Jan 7 2003, 12:19 PM
Jeroen   Hey JP, I guess we have a common goal :D Cheers,...   Jan 7 2003, 02:55 PM
thesey914   Just received Bruce Anderson's book through th...   Jan 18 2003, 05:03 AM
seanery   thesey914, I like your avatar, very nice!   Jan 18 2003, 09:16 AM
thesey914   Thanks :beer2:   Jan 18 2003, 06:37 PM
Brad Roberts   I didnt realize you are located in the UK. Your a...   Jan 18 2003, 11:26 PM
Crawf   Hello, Another fourteener from the UK here, I tho...   Jan 20 2003, 09:36 AM
Dave_Darling   All B's points are true--but still, I like the...   Jan 21 2003, 05:16 PM
campbellcj
- Lo-Fi Version Time is now: 22nd September 2025 - 10:21 PM
