need paint, little tape lesson |
qa1142 |
Sep 22 2006, 05:17 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
(IMG:style_emoticons/default/sad.gif)
So Wednesday i did my first drivers education with Chicago PCA at BlackHawk Farms. Four thirty minute track sessions with a instructor. Had a blast. Ran over 100 track miles. Went to take car #s off and lost ~15" by 2" section of paint off drivers door. Same tape I used last year with no problems (IMG:style_emoticons/default/confused24.gif) now i have to figure out a fixv (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) |
Rusty |
Sep 23 2006, 05:08 AM
Sorry to hear what happened.
Olympic Blue is a solid color. You should be able to have that paint matched... a good body shop should be able refinish the door. If you're going to have one door refinished, consider having both doors done if you're going to use tape on both doors in the future. |
VaccaRabite |
Sep 23 2006, 05:52 AM
En Garde! Group: Admin Posts: 13,445 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
And after that, make surethat you have a good layer of wax on the doors before you put tape or temporary decaled numbers on.
Also, make sure that the door is clean. Zach |
So.Cal.914 |
Sep 23 2006, 11:08 AM
A trick I learned when back tapeing graphics was to pull out the piece of tape I
am going to use and drag it across my pant leg. The tape picks up a little of the fiber and would not pull up the paint I was tapeing off. |
Lo-Fi Version | Time is now: 21st May 2024 - 01:59 PM |
