> Why do points fail?, and how to prevent it?
dion9146
post Sep 25 2006, 07:09 PM
I posted this story on another thread earlier, but I wanted to ask the broader question - why do points fail and how does one prevent that failure?
I have a 2.0 6 cylinder with MSD ignition, MSD Blaster2 coil and stock points. She has been running great since my engine rebuild, but over the weekend I had a problem. Driving along ripping corners in the country on a nice pre-fall day, and all of a sudden she starts running rough. So, I pointed it toward home and put the pedal down. About a mile out, she gave up and died.
After I got my Father to flat tow me home, I started on the MSD diagnostic procedure. I check everything including replacing the coil, and nothing works. I get to the point where MSD recommends pulling the system out and sending it to them for further analysis....that's when I decided to check the points. A couple of passes with the emory cloth, and she cranked right up.
The points are about 5 years old. They have 3 track events, two autocrosses and about 1000 road miles on them, both pre and post rebuild with about 3 years of sitting idle.
So, does my current system contribute to a shorter life span? Hard driving? Sitting for any period of time? Condensor bad?
I just don't want to get in the habit of replacing points every year just because. Any preventive maintenance I can do will be good.
Dion
dion9146   Why do points fail?   Sep 25 2006, 07:09 PM
BMXerror   Points fail because they run on such low voltage. ...   Sep 25 2006, 07:16 PM
Bruce Allert   Points fail due to friction and heat along with le...   Sep 25 2006, 07:19 PM
Matt Romanowski   Most of the issue is the the contact material wear...   Sep 25 2006, 08:57 PM
messix   every time the points open they spark, every spark...   Sep 25 2006, 09:06 PM
dion9146   Thanks for the responses so far guys. After I had...   Sep 25 2006, 09:07 PM
jsteele22   Just to add some physics geek ramblings to what...   Sep 26 2006, 10:54 AM
Toast   My Crane IE failed me last year. I installed poin...   Sep 26 2006, 11:09 AM
Aaron Cox   pertronix = 70 bucks compufire = the same crane xr...   Sep 26 2006, 11:13 AM
tdgray
- Lo-Fi Version Time is now: 6th July 2025 - 12:58 AM
