Anyone running Boxster S front calipers / brakes?, Now I need adapters... |
neo914-6 |
Sep 27 2006, 03:53 PM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Will get them from Rich Johnson if they have the same mount dimensions as standard Boxster calipers.
smdubovsky |
Sep 27 2006, 08:23 PM
Member Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region |
Will get them from Rich Johnson if they have the same mount dimensions as standard Boxster calipers. I dont think so. The bolt spacing is definately the same but I dont know about the offset or height. The BoxS uses the 996 caliper (just painted red). The 996/BoxS stuff bolts right to a base Box (the hub carriers are the same) but I dont know how much the hats/offsets are in the rotor vs the caliper. I have a pair of 996s in the garage if you need me to measure anything, but bill verburg and I had a good discussion on this over on the bird board a few months back if you do a search. The problem is the rotor dims. I dont have my data in front of me but I think they use a 28mm rotor. Different than any other early porsche (except I think a 951). The base box uses a 24mm rotor wich is = to carrera. The 993 and 930 rotors are 32(?) mm wide. The stock 996 rotor hat is all wrong to fit on a 911 hub (and its one piece so you cant simply make another hat). You'd have to find an aftermarket two-peice rotor and make hats. I dont have a clue if the 951 rotor can be adapter to a 911. Its far simpler (and cheaper) to stick w/ box calipers on carrera rotors, or 993 calipers on 930 rotors. I guess its possible to shave the pins (and pads) to fit them over a 32mm rotor like some guys do w/ the 993 rears. Im shimming the bridge of mine so I dont have to mess w/ that every pad change (Im putting 993s on the tail dragger) Best, SMD |
gregrobbins |
Sep 27 2006, 08:58 PM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
Check with Wild6, I think Andy has them on his car.
MrKona |
Sep 27 2006, 09:36 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
There was a 914-6 profiled in the October 2006 issue of Excellence that uses Boxster calipers with adapters made by TRE Motorsports. Hope this may help.
TRE Motorsports |
bryanc |
Sep 27 2006, 09:38 PM
Member Group: Members Posts: 321 Joined: 9-August 04 From: San Antonio, Tx Member No.: 2,495 Region Association: Southwest Region |
MrKona |
Sep 27 2006, 09:39 PM
dakotaewing |
Sep 27 2006, 09:47 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
Call Rich Johnson for the adapters -
He probably has a dozen sets laying around.... LOL |
neo914-6 |
Sep 27 2006, 09:55 PM
Call Rich Johnson for the adapters - He probably has a dozen sets laying around.... LOL His and TRE are for standard Boxster calipers (Brembo Monoblock) but not all "S" depending on the part number. Anyone know the differences? I found some adapters at msroadrace store on eBay... (IMG:style_emoticons/default/smile.gif) QUOTE This is a adapter to mount 94-98 993 / 993TT calipers to a 69 to 89 type 911 / 930. It converts a top mount caliper to a side mount. They say the Box S as well...Attached image(s) |
neo914-6 |
Sep 27 2006, 10:09 PM
So true with complete new kits but with my shopping luck, I won used but fairly new 4 pot calipers for $400 BTW, the auction lists them same as 996... |
Andyrew |
Sep 27 2006, 11:07 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
STOP
(hehe) jk.. Thats alot of caliper for neo, dude!! I think im going to be major overkill with 944 turbo calipers up front... Andrew |
sj914 |
Sep 28 2006, 01:30 AM
Senior Member Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 |
Call Rich Johnson for the adapters - He probably has a dozen sets laying around.... LOL His and TRE are for standard Boxster calipers (Brembo Monoblock) but not all "S" depending on the part number. Anyone know the differences? I found some adapters at msroadrace store on eBay... (IMG:style_emoticons/default/smile.gif) QUOTE This is a adapter to mount 94-98 993 / 993TT calipers to a 69 to 89 type 911 / 930. It converts a top mount caliper to a side mount. They say the Box S as well...Those 993 adaptors use the big red calipers. They are huge and uses thicker rotors. I'm not sure about the "s" calipers, but what I have on my project are boxster monoblocks using the carrera 24mm front rotors and sc 20 mm rear rotors. From what I've read about the "s" calipers is that they use a 28 mm front and 24 mm rear. So pretty much all it does is it allows for wider rotors and the pistons are bigger. |
neo914-6 |
Sep 28 2006, 03:04 AM
Call Rich Johnson for the adapters - He probably has a dozen sets laying around.... LOL His and TRE are for standard Boxster calipers (Brembo Monoblock) but not all "S" depending on the part number. Anyone know the differences? I found some adapters at msroadrace store on eBay... (IMG:style_emoticons/default/smile.gif) QUOTE This is a adapter to mount 94-98 993 / 993TT calipers to a 69 to 89 type 911 / 930. It converts a top mount caliper to a side mount. They say the Box S as well...Those 993 adaptors use the big red calipers. They are huge and uses thicker rotors. I'm not sure about the "s" calipers, but what I have on my project are boxster monoblocks using the carrera 24mm front rotors and sc 20 mm rear rotors. From what I've read about the "s" calipers is that they use a 28 mm front and 24 mm rear. So pretty much all it does is it allows for wider rotors and the pistons are bigger. That's the combo for standard Boxster calipers, what I need are the 996/Boxster S. Chris Julian said he has all the dimensions for the required rotors since he installed the 996TT calipers. Talking about huge, I wanted Cayenne calipers but would have to get special brackets fabricated. Gotta fill those 18" wheels... (IMG:style_emoticons/default/biggrin.gif) |
sj914 |
Sep 28 2006, 03:54 AM
Call Rich Johnson for the adapters - He probably has a dozen sets laying around.... LOL His and TRE are for standard Boxster calipers (Brembo Monoblock) but not all "S" depending on the part number. Anyone know the differences? I found some adapters at msroadrace store on eBay... (IMG:style_emoticons/default/smile.gif) QUOTE This is a adapter to mount 94-98 993 / 993TT calipers to a 69 to 89 type 911 / 930. It converts a top mount caliper to a side mount. They say the Box S as well...Those 993 adaptors use the big red calipers. They are huge and uses thicker rotors. I'm not sure about the "s" calipers, but what I have on my project are boxster monoblocks using the carrera 24mm front rotors and sc 20 mm rear rotors. From what I've read about the "s" calipers is that they use a 28 mm front and 24 mm rear. So pretty much all it does is it allows for wider rotors and the pistons are bigger. That's the combo for standard Boxster calipers, what I need are the 996/Boxster S. Chris Julian said he has all the dimensions for the required rotors since he installed the 996TT calipers. Talking about huge, I wanted Cayenne calipers but would have to get special brackets fabricated. Gotta fill those 18" wheels... (IMG:style_emoticons/default/biggrin.gif) If you wanna fill the 18" wheels take a look at these guys. linky |
smdubovsky |
Sep 28 2006, 08:57 AM
That's the combo for standard Boxster calipers, what I need are the 996/Boxster S. Chris Julian said he has all the dimensions for the required rotors since he installed the 996TT calipers. Talking about huge, I wanted Cayenne calipers but would have to get special brackets fabricated. Gotta fill those 18" wheels... (IMG:style_emoticons/default/biggrin.gif) What rotors (and hat) are you using? Thats what controls the dimensions of the adapter. Buying the adapter before the rotor is putting the cart before the horse. SMD |
neo914-6 |
Sep 28 2006, 11:13 AM
[/quote]
If you wanna fill the 18" wheels take a look at these guys. linky [/quote] I guess you missed Chris' thread, I sent the VCI link. (IMG:style_emoticons/default/wink.gif) |
neo914-6 |
Sep 28 2006, 11:14 AM
That's the combo for standard Boxster calipers, what I need are the 996/Boxster S. Chris Julian said he has all the dimensions for the required rotors since he installed the 996TT calipers. Talking about huge, I wanted Cayenne calipers but would have to get special brackets fabricated. Gotta fill those 18" wheels... (IMG:style_emoticons/default/biggrin.gif) What rotors (and hat) are you using? Thats what controls the dimensions of the adapter. Buying the adapter before the rotor is putting the cart before the horse. SMD (IMG:style_emoticons/default/agree.gif) likely $ VCI but still researching... |
neo914-6 |
Sep 29 2006, 06:50 PM
instant-G's has an adapter kit with special machined 996 hubs, wheel bearings, seals and caps, and two adapters, hardware. It uses stock 996 330x34mm (13 x 1.34") ventilated rotors which is good from the wear replacement aspect. FYI, min wheel size is 17".
Chris fabbed his own brackets to fit 996TT calipers and turned down 930 rotors to 12.45" to fit in 16" HRE modular wheels. No response from VCI yet. |
smdubovsky |
Sep 29 2006, 08:34 PM
instant-G's has an adapter kit with special machined 996 hubs, wheel bearings, seals and caps, and two adapters, hardware. It uses stock 996 330x34mm (13 x 1.34") ventilated rotors which is good from the wear replacement aspect. FYI, min wheel size is 17". Chris fabbed his own brackets to fit 996TT calipers and turned down 930 rotors to 12.45" to fit in 16" HRE modular wheels. No response from VCI yet. Felix, The 34mm wide rotor is for the 996TT and 993TT brakes. BoxS/996 calipers are *NOT* 996TT calipers. The BoxS/996 use a 28mm rotor. Which caliper do you have? AFAIK, those 993tt/996tt kits use the 993tt rotor since it will fit over an early 911 hub easily w/ a custom hat. Chris turned down larger rotors close to that of a 930 so they will fit under his wheels (right thickness, but 930s are too small to start w/ - I think only 12". That why he haad to start w/ the larger OD rotor). You cant easily put 996 rotors on a 911 because the 996 slip over the hub, the 911 bolt behind the hub. Even if you redrilled the 996 bolt holes to the right size, the hat is about 15mm deeper - the rotor will likely hit the strut or leave zero room for the caliper between it and the strut. It looks possibe to turn down the OD of a 911 hub to fit the 996 rotor (about 160mm ID), but its going to take ALOT of meat off the 911 hub. Strength might be an issue. I *THINK* timmons machines a 951 hub for some of his kits but that has been just speculation on the boards. FWIW, I have 996 hubs, brakes, rotors, and 911/930 hubs in the garage to try and figure all this stuff out. It doesn't look really easy to fit 996 brakes to a 911/914 (which is why I bought a 993 backup set;) You're best bet is to find some aftermarket brembo/alcon rotor thats 28mm thick and make a custom hat. Then it'll be a no brainer. Edit: looking at the timmons kit its definately a 996 part (well, technically a 996tt part). Maybe the 996tt rotor has a larger ID and doesn't require turning so much material off the hub. *IF* you have 996tt calipers, if might not be a bad way to go (but why not just use 993tt rotors - darn near same size, lighter (w/ aluminum hat), no hub machining, and they are trick 2 peice bits?) SMD |
neo914-6 |
Sep 29 2006, 09:16 PM
Felix, The 34mm wide rotor is for the 996TT and 993TT brakes. BoxS/996 calipers are *NOT* 996TT calipers. The BoxS/996 use a 28mm rotor. Which caliper do you have? Edit: looking at the timmons kit its definately a 996 part (well, technically a 996tt part). Maybe the 996tt rotor has a larger ID and doesn't require turning so much material off the hub. *IF* you have 996tt calipers, if might not be a bad way to go (but why not just use 993tt rotors - darn near same size, lighter (w/ aluminum hat), no hub machining, and they are trick 2 peice bits?) SMD I bought 996/Boxster S calipers, I misquoted the rotor size since Timmons said to refer to the 966TT kit on his website. The 966 kit is "similar". I like that it's a developed bolt-on kit even though Chris is willing to do the machining for my 996 calipers. I "could" get Boxster or 993 calipers with more mounting options if I had more time... (IMG:style_emoticons/default/smile.gif) |
ovilla |
Sep 29 2006, 10:21 PM
Member Group: Members Posts: 84 Joined: 25-February 05 From: Plainfield, IL Member No.: 3,660 |
Just curious. Can you run 15" 911 fuchs using Boxster non-S mono's front and back? Sorry, didn't mean to hijack but I figured that this may be the right audience to address this. I'd like to run even bigger brakes but don't want to part with my 15X6's just yet. Thanks
Lo-Fi Version | Time is now: 2nd May 2024 - 11:13 AM |
