Do you properly torque your wheels? |
Mueller |
Oct 30 2003, 05:55 PM
With the new vented /4 front hub coming out soon (prototype next week I hope), proper torque of the wheel bolts will be critical as in not too tight.
(factory specs okay) There is a safety factor built in of course, but if you don't use a torque wrench and have the strength of a gorilla, "something" is going to give (IMG:style_emoticons/default/sad.gif) (IMG:http://www.914world.com/bbs2/uploads/post-3-1067558082.jpg) |
ChrisReale |
Oct 30 2003, 05:56 PM
I aklways torque to 94 lbs. The one time I didn't, my wheel fell off while I was driving. Lucky fir me I was only going 15mph at the time (IMG:style_emoticons/default/ohmy.gif)
Part Pricer |
Oct 30 2003, 06:01 PM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
I torque my nuts at least once a week...wait, that didn't sound right. (IMG:style_emoticons/default/ohmy.gif)
I check the torque of the lug bolts on my car at least once a week. Ah, better. If I'm going to an AX, I will check the torque before I leave the house, check the torque before I run, and check the torque again after the event before I head home...and I mean the lug bolts. (IMG:style_emoticons/default/rolleyes.gif) |
Air_Cooled_Nut |
Oct 30 2003, 06:09 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
I torque lugs/nuts to spec then after 50-100 miles I check them to make sure then that's it until they come off again.
Bruce Allert |
Oct 30 2003, 06:38 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
Yup. Just before AX & everytime I take a wheel off to do sumpin. I been torquing to 95#
bruce |
Oct 30 2003, 07:47 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
100 lbs all around ...
Andy |
davep |
Oct 30 2003, 07:58 PM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Yes, in three steps 60, 80, 95.
When I worked in a VW+Audi dealer we had tires changed at local shops. They used the air gun to put the wheels back on and would warp the rotors. That was far too expensive. Did I ever ream them out for the practice. And do not lube the bolts/nuts. That can cause you to over-torque a fastener. It is not a trivial exercise despite appearances. I'm forever having to remind the production team on why the rules have to be followed. DaveP |
Aaron Cox |
Oct 30 2003, 08:35 PM
QUOTE(ChrisReale @ Oct 30 2003, 04:56 PM) I aklways torque to 94 lbs. The one time I didn't, my wheel fell off while I was driving. Lucky fir me I was only going 15mph at the time (IMG:style_emoticons/default/ohmy.gif) same thing happened to me...same speed. wheel got jammed between road and fender and caused some havoc....bodywork YAY! (IMG:style_emoticons/default/ohmy.gif) |
Curvie Roadlover |
Oct 31 2003, 05:08 AM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
Little bit of anti-seize and 95 lbs (IMG:style_emoticons/default/wink.gif)
JWest |
Oct 31 2003, 08:01 AM
Mike, you are asking this for the screw-in version of the hubs, right?
IMHO I believe you should only offer pressed-in type studs with alumunim hubs. There is just too much risk of screwing the threads up over the many times they will be on and off. If someone already has the long bolts for factory alloys, I think they could sell those and make up a good portion of the money to buy 911 studs and nuts anyway. |
davep |
Oct 31 2003, 08:32 AM
For a design such as this, studs and nuts would be much preferred. New nuts are cheaper than a new hub. DaveP |
fiid |
Oct 31 2003, 09:54 AM
I agree - I much prefer to play with nuts. Errr..... I mean - it's nice to be able to drop the wheel on the studs while you fuble around trying to get the lugs on - it's hard work holding the wheel up while you get that first lug in with the stock system.
Fiid. |
silver six |
Oct 31 2003, 03:46 PM
Member Group: Members Posts: 203 Joined: 3-February 03 From: San Bruno, California Member No.: 227 |
If I'm not mistaken it's 94 lb/ft for five lug and 108 lb/ft for four lug. Word to your mother.
Douglas |
Part Pricer |
Oct 31 2003, 03:55 PM
Correct me if you're wrong, but I believe the following to be true:
It is 96 lb/ft for alloys (Fuchs 4 or 5 bolt, Pedrinis, Mahles) and 104 lb/ft for steel wheels. |
Curvie Roadlover |
Oct 31 2003, 03:59 PM
QUOTE(Paul Heery @ Oct 31 2003, 01:55 PM) Correct me if you're wrong, but I believe the following to be true: It is 96 lb/ft for alloys (Fuchs 4 or 5 bolt, Pedrinis, Mahles) and 104 lb/ft for steel wheels. Yes (IMG:style_emoticons/default/agree.gif) Gots to go easy on the alloys (IMG:style_emoticons/default/wink.gif) |
markb |
Oct 31 2003, 04:07 PM
We generally do 85 lbs for alloys at the shop. Is that too little?
Part Pricer |
Oct 31 2003, 04:18 PM
OK. You just made me dig out my VW/Porsche 914 Repair Guide, a Glovebox series book by Peter R.D. Russek., published by Peter Russek Publications Ltd.
According to this comprehensive technical manual: Standard (steel): 15 kgm (108 lb. ft.) Light Alloy : 13 kgm (94 lb. ft.) Based on this, I would say that 85 lb. ft. is well below spec. |
silver six |
Oct 31 2003, 04:19 PM
QUOTE(Paul Heery @ Oct 31 2003, 01:55 PM) Correct me if you're wrong, but I believe the following to be true: It is 96 lb/ft for alloys (Fuchs 4 or 5 bolt, Pedrinis, Mahles) and 104 lb/ft for steel wheels. According to the Porsche Factory Shop Manual you would be mistaken. And thus corrected. Torques in parenthesis are for the 914-6 (i.e. the 5 lug nut pattern wheels). Higher 108 lb/ft torque is for the 914-4 lug bolts. Attached thumbnail(s) |
Part Pricer |
Oct 31 2003, 04:36 PM
I see the source of the confusion. You are using an older version of the manual. (IMG:style_emoticons/default/wink.gif)
If you look at the version published in 1974, you will see that Porsche specified: For 25mm bolts (for steel wheels): 108.5 Lb. ft. For 39mm bolts (for alloy wheels): 94 lb. ft. For nuts: 94 lb ft. So, we both are right. Wanna grab a beer? (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
roundboy914 |
Oct 31 2003, 06:11 PM
Member Group: Members Posts: 210 Joined: 16-October 03 From: Chicago, IL Member No.: 1,251 |
94 lb/ft, and do NOT forget the anti sieze.
Lo-Fi Version | Time is now: 8th May 2024 - 09:59 PM |
