What first? |
What first? |
ChrisReale |
Mar 4 2003, 10:39 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
I have 180 lb springs and Koni Sports all around. Stock toothpick sized sway bar up front. What would be the first thing you would do...
1. Put in a 22mm Sway Bar 2. Put in 22mm Torsoin bars (IMG:style_emoticons/default/confused24.gif) |
J P Stein |
Mar 5 2003, 03:45 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
IMO, 180 lb springs are too much with stock T bars/sway bar.....they will make it LOOSE. 140s are a better choice.
I was able to get a nice slight oversteer condition using an adjustable front sway bar and the 140 lb springs......set soft, so your small sway bar may be OK....close enuff that tire pressure can get you where you wanna go. Geoff's right, just drive, butt time is the key. DD tole me that back a bit....the only time he's been right, me thinks. (IMG:style_emoticons/default/rolleyes.gif) Get the car handling decent early in the season, then leave it alone. Then you can measure your driving improvments. You can work on hot rodding the car for the rest of your winters (IMG:style_emoticons/default/biggrin.gif) . |
Lo-Fi Version | Time is now: 19th May 2024 - 06:06 AM |
