What first? |
What first? |
ChrisReale |
Mar 4 2003, 10:39 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
I have 180 lb springs and Koni Sports all around. Stock toothpick sized sway bar up front. What would be the first thing you would do...
1. Put in a 22mm Sway Bar 2. Put in 22mm Torsoin bars (IMG:style_emoticons/default/confused24.gif) |
airsix |
Mar 5 2003, 01:39 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
I'm with JP. That combo (180# rears and stock fronts) is a scary-loose combo with a stock front sway bar. Scary-big oversteer. "I'm going 70mph backwards and I'm going to die" oversteer.
If you are going to keep the 180# rears then start saving your $ and get a 19mm or larger front sway bar AND 21mm or 22mm torsion bars. That is if you are sure you want to stay with 180# rears. That's what I run, but I'm nuts. I'm running the 180#'s, 21mm torsion bars and 19mm sway bar set at medium. Even with that setup its loose (not scary loose, but plenty loose none the less*). -Ben M. *plenty loose = only got away from me twice last year. |
Lo-Fi Version | Time is now: 19th May 2024 - 02:53 AM |
