911 Front Rotor Bolt Torque Spec? |
Spoke |
Oct 6 2006, 08:40 AM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
What is the torque spec for the 911 front rotor to hub bolts?
Thanks, Spoke Attached image(s) |
Spoke |
Oct 6 2006, 12:44 PM
The pieces cleaned up real nice. The original paint is still in good shape so I won't be painting things now. Bearings, ball joint, tie rod ends seem to be in good shape. Will find out for sure when installed.
The shiny part of the caliper is where rustproofing was inadvertently sprayed. Anyone have the torque specs for the rotor-to-hub bolts? Thanks, Spoke Attached image(s) |
Cap'n Krusty |
Oct 6 2006, 01:19 PM
Torque all hex head 8.8 bolts to 14-18 ft lbs. The Cap'n
Eric_Shea |
Oct 6 2006, 01:31 PM
I take it you don't need the window regulator? (IMG:style_emoticons/default/smile.gif)
(back in storage I guess) |
Spoke |
Oct 6 2006, 04:56 PM
Torque all hex head 8.8 bolts to 14-18 ft lbs. The Cap'n Thanks Cap'n!! I take it you don't need the window regulator? (IMG:style_emoticons/default/smile.gif) (back in storage I guess) Umm, was the regulator for me? I'm not in need of one. Thanks anyway. Are you still looking for rear trailing arms? I should be about 2-4 weeks from replacing the rear arms on the green car. Let me know if you want them. Spoke |
Eric_Shea |
Oct 6 2006, 06:33 PM
Sorry... got you mixed up with Solex. You actually reply to PM's (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 19th May 2024 - 07:15 AM |
