1975 911S tranny?, What model is it, and is it a good upgrade for the 914. |
jaybird840 |
Oct 6 2006, 04:36 PM
Member Group: Members Posts: 163 Joined: 27-September 06 From: Austin, TX Member No.: 6,927 Region Association: Southwest Region |
Hi All,
Came across a 5sp gearbox from a '75 911S recently. It can be had for <$500. Is it a good upgrade for the 914??? (if you're eventually gonna push much more HP than stock). TIA. --Jaybird840 No 914 yet.... got my eye on one, tho. '82 Mercedes 380sl |
jd74914 |
Oct 6 2006, 04:47 PM
Its a 915 tranny. You only really want one if you're putting in a big hp engine (like a 3.6L /6 or a v8)
So.Cal.914 |
Oct 6 2006, 04:49 PM
I believe it is a 915, and yes I sacrafice small animals to an effigy in the shape
of a 915. |
Cap'n Krusty |
Oct 6 2006, 05:06 PM
1975 915s have nearly ALL the uncorrected faults of the series. The first year you want is an 82. The Cap'n
Bleyseng |
Oct 6 2006, 05:21 PM
its a 915 and only switch to it if you are planning on a high hp six. It will need a few conversion parts $$$$ to make it work. It should be checked over as there are a few problems with loose bearing saddles.
GeorgeRud |
Oct 6 2006, 05:57 PM
It does however have the course splined stub axles that allow you to simply plug in the 914 axles. Budget about $4000 to the price of the transaxle to end up with a good, useable trans for your project. They are good but expensive.
Also, 1975 has the oddball release lever on the clutch release arm that doesn't fit anything. |
Lo-Fi Version | Time is now: 19th May 2024 - 12:58 PM |
