Rear Trunk Help, GRR! annoying! |
mrhurtalot |
Oct 9 2006, 09:25 AM
VRRRRRRROOOOOOOOOM! Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 |
ok, i have a 74 2.0 teener. and when i go to press the trunk release button the latch pops, then unpops, the second i let off the button.
what causes this? oh and i cant just use a key because i have a 911 reflector Porsche logo over where the key hole is... arg.! (IMG:style_emoticons/default/sawzall-smiley.gif) |
John |
Oct 9 2006, 09:29 AM
It could be a simple alignment issue between the lower and upper latch components.
It could also be a weak spring in the upper portion of the rear trunk lid latch. Do you have a wing or tail mounted to the rear trunk lid? Extra weight may be tough for the latch spring to overcome. just a couple thoughts. |
Lo-Fi Version | Time is now: 21st May 2024 - 03:49 PM |
