2.0 fuel mileage, what do you get from a DD |
toon1 |
Oct 9 2006, 04:46 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I'm thinking about building a 2L. I have most of the parts needed for the build. It will be 96mm,9550 raby cam with megasquirt. nothing crazy, it's a daily driver. I'm curios about the fuel economy.
What kind of mileage do you guy's get from your 2.0??? |
JoeSharp |
Oct 9 2006, 05:01 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
merrill |
Oct 9 2006, 05:23 PM
Dirt Pimp Group: Members Posts: 224 Joined: 25-January 05 From: Tahoe City, Ca Member No.: 3,505 Region Association: None |
29 mpg with webber 40idf.
draperjojo |
Oct 9 2006, 05:24 PM
sixstrings Group: Members Posts: 411 Joined: 26-December 05 From: Salt Lake City Utah Member No.: 5,317 |
Left RRC with a full tank, and drove 208 miles to Draper Utah and it took 5.52 gallons to fill it again. 37.68 mpg on the highway cruising at 65-70mph.
jsf322 |
Oct 9 2006, 05:34 PM
Member Group: Members Posts: 83 Joined: 1-December 05 From: Baldwin, New York Member No.: 5,220 |
Before I started having issues with my stock 1976 2.0, I was getting between 20 and 32 mpg depending on how hard I drove it and whether it was highway or around town.
Bleyseng |
Oct 9 2006, 05:49 PM
29mpg when my 2056 was running the stock cam, stock FI, stock gears, 50 series tires.
Now with lower gears, 9550 cam, I can't stay off the gas so its way lower. |
BMartin914 |
Oct 10 2006, 08:26 AM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
33.5 MPG on the 250 mi +/- stretch of I-70 between Grand Junction and Denver on the way back from RRC.
SGB |
Oct 10 2006, 08:47 AM
weber 40s and webcam-
Tuning REALLY influences mpg for me. When valves, linkage, balance, and the combo of 50 mains with 115 air correctors and 2.5 turns out on both air bypass and mix control screws all line up with the stars and planets, I'll get about 35mpg at a steady 75 mph, but only 20 or so around town. I could prolly get 25 or 26 in town with more restraint. Recently got some crap in one of the carb passages and although performance seemed only moderately reduced (torque seemed low in mid-range RPMs) but it was sucking the gas big time. |
Demick |
Oct 10 2006, 09:14 AM
I have a similar setup to what you want to build (except modified d-jet instead of MS). I average 24mpg if I drive conservatively. 20 if I am not so conservative.
Jake Raby |
Oct 10 2006, 09:20 AM
With that set up and 8.3:1 (thats the recommended compression ratio for that arrangement) you should have no problem getting 30 MPG with stable driving and 25 wityh spirited driving..
Thats dependant upon the wear on your tranny, your tire size and how smooth of a driver you are.. I have had customers report 35 MPG from that cam set up in a 914, but the most I have experienced was 31 IIRC.. |
Howard |
Oct 10 2006, 09:42 AM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
Stock 2.0 FI. Never really drive it in traffic, but normal use (50 series tires, canyon dancing) 22mpg. Trip to Moab (65 series tires, high speed cruising) over 30mpg, one leg 37mpg. Track weekend (200 mi RT to Willow, 1.5 hours track time) 20mpg. I do drive there with the 50's on.
Did I mention this is a great car? Cheap to run, race, maintain, and just play with. |
aveale |
Oct 10 2006, 10:03 AM
Fun Times Group: Members Posts: 194 Joined: 18-August 04 From: Ottawa, Canada Member No.: 2,563 |
20-25mpg driving somewhat like a normal person.
I certainly would question 35mpg or greater from a 30 year old car. T |
toon1 |
Oct 10 2006, 10:33 AM
All the resposes aren't much different from what I am getting with my 1.7. I average about 25 mpg. commuting around town and to work (9 mi. one way). The motor is not exactly running perfect, I would think it should do better.
I'm running 195/60 tires, stock tranny and D-jet. I spins about 3100 @70 mph. Is there a taller 5th gear for the 901 tranny's? |
Jake Raby |
Oct 10 2006, 11:10 AM
20-25mpg driving somewhat like a normal person. I certainly would question 35mpg or greater from a 30 year old car. T Its all in the combo.. I have have had many 100% stock engines get over 30 MPG in 914s with optimized tuning, most of the time even with mods the MPG stays up at that level or even more. The engine in my 912E has now 107K on it after a build in 2002 to my best set up at the time. That engine, even today get 30-32 on average and thats after not having an oil change for 23K miles! It has gotten a best of 40 MPG with a female driver, the best I have gotten with it is 37 MPG when it had about 20K miles on the clock A fellow in the Netherlands that posts on the STF has gotten 36 MPG from his 140 HP 2056cc engine, follow this post to see the results. Wally's post He is a well respected tuner that has no reason to lie... I won't even bother trying to explain how one of my Super 2 Liter builds is getting 45 MPG and makes 145HP... When I open the lid on that can of worms it'll be on my new forums :-) The age of the engine has nothing to do with the MPG, its totally dependant upon the driving style, tuning and COMBO! BTW- for many years I took care of a 912E that belonged to a little old lady that bought it new- she kept track of mileageand service like it was her only job.. One day while in her glovebox looking for the wheel lock I saw her mileage notes and looked at them closer.. It seemed the worst mileage she was getting was 36 MPG and a best of 44! I asked her about the notes when she came to get the car, she replied that that was nothing and after my tune up she had gotten 47 MPG before.. The next time the car came in my shop I made it a point to check the odometer with the old mile post method.. Hers was only about 1/10 off from the mile post... She retired that engine with 321K miles on the original bottom end still getting over 30 MPG! Now I have it out back, as a parts car after it was totaled 4K miles after my full engine rebuild :-( |
toon1 |
Oct 10 2006, 11:37 AM
20-25mpg driving somewhat like a normal person. I certainly would question 35mpg or greater from a 30 year old car. T Its all in the combo.. I have have had many 100% stock engines get over 30 MPG in 914s with optimized tuning, most of the time even with mods the MPG stays up at that level or even more. The engine in my 912E has now 107K on it after a build in 2002 to my best set up at the time. That engine, even today get 30-32 on average and thats after not having an oil change for 23K miles! It has gotten a best of 40 MPG with a female driver, the best I have gotten with it is 37 MPG when it had about 20K miles on the clock A fellow in the Netherlands that posts on the STF has gotten 36 MPG from his 140 HP 2056cc engine, follow this post to see the results. Wally's post He is a well respected tuner that has no reason to lie... I won't even bother trying to explain how one of my Super 2 Liter builds is getting 45 MPG and makes 145HP... When I open the lid on that can of worms it'll be on my new forums :-) The age of the engine has nothing to do with the MPG, its totally dependant upon the driving style, tuning and COMBO! BTW- for many years I took care of a 912E that belonged to a little old lady that bought it new- she kept track of mileageand service like it was her only job.. One day while in her glovebox looking for the wheel lock I saw her mileage notes and looked at them closer.. It seemed the worst mileage she was getting was 36 MPG and a best of 44! I asked her about the notes when she came to get the car, she replied that that was nothing and after my tune up she had gotten 47 MPG before.. The next time the car came in my shop I made it a point to check the odometer with the old mile post method.. Hers was only about 1/10 off from the mile post... She retired that engine with 321K miles on the original bottom end still getting over 30 MPG! Now I have it out back, as a parts car after it was totaled 4K miles after my full engine rebuild :-( would this combo be the most efficiant 2.0 DD ?(96mm,71stroke) |
Toast |
Oct 10 2006, 12:27 PM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
I get about 20-25 mpg depending on how high my idle is that day (vacuum leak makes it vary from 1100-1600 at any given time)and if I have a loose valve and how much in town driving i'm doing.
I have a stock 2.0 with FI and drive the speed limit. (traffic permitting that I can even go that fast) |
Jake Raby |
Oct 10 2006, 01:18 PM
QUOTE would this combo be the most efficiant 2.0 DD ?(96mm,71stroke) Its the best if you want something easy to create.. The "Best" so far in my experience has been the Super 2 Liter I have been working on for about 2 years now.. Its still a 2.0, weighing in at 2016cc, but it gains its displacement through a stroker crank and a smaller bore.. The combo is 78.4X90 and benefits from super intake velocities and excellent mixture quality. Couple that to a sweetheart of a cam and its a 40 MPG engine on a bad day. I have one of these combos ready to go in the 912E as soon as the current engine expires, which may be a while.. I am building a Turbo version of this for my wife's convertible Bug.. :-) |
914fan |
Oct 10 2006, 02:31 PM
Member Group: Members Posts: 118 Joined: 17-January 05 From: Fountain Valley CA Member No.: 3,460 |
Jake,
145hp is cool, but aprox what is the TQ? I know you don't want to "Open the can of worms", but can you just say over 100, 120, 500!!!! (I wish) |
jd74914 |
Oct 10 2006, 06:27 PM
20-25mpg driving somewhat like a normal person. I certainly would question 35mpg or greater from a 30 year old car. T My dad swears he got 35 in his, and swears that it rean perfectly (ie: not lean). I have no reason to doubt that any 914 can get gas mileage that good. Why can't old cars get mpg figures that high. I mean, when the engines are worn they may get less mpg, but with a rebuilt engine to stock there is no reason you shouldn't get over 30 on the highways atleast with d-jet or carbs. (IMG:style_emoticons/default/smile.gif) |
JoeSharp |
Oct 10 2006, 09:25 PM
You guys haven't mentioned carbs before. Linda and Thomas are both getting over 40 on long trips. Linda got 49 at one point, but we had to change the dizzy trying to do better. Now the best she gets is 45mpg.
Dual singles. :PERMAGRIN: Joe |
Lo-Fi Version | Time is now: 21st May 2024 - 01:39 AM |
