Initial Diagnosis, Fritz is hurt... |
Mueller |
Oct 15 2006, 01:25 PM
Bill, Here are a few links about the belt failure, damage looks just like yours.... belt failure 3.6 dizzy belt issues a little more reading If I can find my CD, I'll burn you a copy which has directions and pictures on the replacing the belt. Took me a couple of hours start to finish Bill, Did your distributor have a "vent kit" installed, as outlined in Mike's documenation above? Any way to modify the assembly to get rid of the belt? Convert the motor to crankfire for sure...it might be possible to make it gear driven, being that it's a race car, using straight cut gears wouldn't be too big of deal... |
nine14cats |
Oct 15 2006, 01:47 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
Bill, Here are a few links about the belt failure, damage looks just like yours.... belt failure 3.6 dizzy belt issues a little more reading If I can find my CD, I'll burn you a copy which has directions and pictures on the replacing the belt. Took me a couple of hours start to finish Bill, Did your distributor have a "vent kit" installed, as outlined in Mike's documenation above? Any way to modify the assembly to get rid of the belt? Convert the motor to crankfire for sure...it might be possible to make it gear driven, being that it's a race car, using straight cut gears wouldn't be too big of deal... For now I'm going back in with the belt. Given The Beast and Boxster builds are underway, I don't want the cash outlay for the crankfire. Bill P. |
ConeDodger |
Oct 15 2006, 06:43 PM
Apex killer! Group: Members Posts: 23,575 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
You might want to pass what you found by Jerry W. "It appear that the secondary shaft is wacked. It does not spin true." How would that happen??? Might have Ted check the crank to be sure it is not bent. Ken Hi Ken, The secondary disty is not wobbly, but is "sticky" compared to the primary. With a broken belt, you would think it would spin freely. We still have to pull the distributor apart. I wasn't planning on pulling aprt the bottom end. Bill P. Suppose for a second that the sticky shaft preexisted the broken belt. It could have caused the broken belt... |
nine14cats |
Oct 15 2006, 07:22 PM
You might want to pass what you found by Jerry W. "It appear that the secondary shaft is wacked. It does not spin true." How would that happen??? Might have Ted check the crank to be sure it is not bent. Ken Hi Ken, The secondary disty is not wobbly, but is "sticky" compared to the primary. With a broken belt, you would think it would spin freely. We still have to pull the distributor apart. I wasn't planning on pulling aprt the bottom end. Bill P. Suppose for a second that the sticky shaft preexisted the broken belt. It could have caused the broken belt... That is a definite possibility. That's why we are going to rebuild the disty as well. Catastrophy from a distributor issue.... What's the world coming to.... (IMG:style_emoticons/default/wacko.gif) Bill P. |
Brad Roberts |
Oct 16 2006, 01:27 PM
Bill,
RobJ has a 3.6 dizzy sitting on cart if you want me to bring a spare with me. Nice finding out about the "slip fit" cams huh?? Scary ?? Did you pull the codes from the computer? B |
Lo-Fi Version | Time is now: 4th May 2024 - 09:32 AM |
