Thoughts on a Subi / Automatic setup? |
WildWheeler |
Oct 13 2006, 09:46 AM
Newbie Group: Members Posts: 6 Joined: 6-September 04 From: Calgary AB Canada Member No.: 2,703 |
Hey Gang and Subi Guru's,
I am thinking about doing a Subaru motor with a Subaru automatic transmission. Has anyone done this yet? What will the biggest challenges be? I am just wanting a reliable daily driver, don't need any extra hp, so I am thinking of the Forester motor? The reason for the auto is that I require hand controls to drive. Thank you in advance for all your help! I love this site! Cheers, Scott aka Wheels |
TravisNeff |
Oct 13 2006, 10:02 AM
Been done by our brother down under. Do a search for "banksyinoz"
jsteele22 |
Oct 13 2006, 11:37 AM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
Probably not a big issue, but just in case... The auto tranny is controlled by computer, so this would mean you have to stick with the ECU from Subaru. So no MegaSquirt, SDS, etc., unless you run them in addition to the stock ECU. But a lot of people (most ?) do just grab the ECU and harness from a Subie. And since you actually have the AT, there would be fewer sensors to fake. Also, I believe (somebody correct me !) that the ECU is specific to the tranny - you can't use one from a car with a manual tranny. If you're able to get all your parts - engine, tranny, sensors, harness, ECU - from the same car, the job will be a lot easier. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:10 AM |
