Heavy Metal, What to cut or not to cut. That is the question |
vincesix |
Oct 19 2006, 03:42 PM
Newbie Group: Members Posts: 38 Joined: 20-December 04 From: Riverside,CA Member No.: 3,313 |
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) I want to lighten up the 914. I want to remove some metal as opposed to buying a bunch of fiberglass. I will weld in a chrome moly cage but like my doors and hoods. What happens when the rear trunk floor is removed ( not supports or cross bracing ) to the cars ridigity? Is their an issue with dirty air to the engine with the tin and rear wall removed? How much weight is in those doors ?(73). I thinking glass, regulator cross brace removal. And lastly how do you get around the wiring harness to remove the sound deading material quickly? (IMG:style_emoticons/default/av-943.gif)
Mueller |
Oct 19 2006, 04:19 PM
are you build a real race car or a ricky-the-road-racer type deal???
for a streetable car, you'll want to keep the engine tin, the rear wall is a structual member |
Bleyseng |
Oct 19 2006, 05:08 PM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Streetable or raceing only?
for the street fiberglass front and rear trunks saves alot of weight as do bumpers. |
JPB |
Oct 19 2006, 05:29 PM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
The floors are structural bro. I don't see how them fellas can take a floor out and get less weight with the new tubing. I guess it winds up being a whole lot stiffer though.
(IMG:style_emoticons/default/beer.gif) Sheradon standard fiberglass body parts my brother "SHERADON" and don't look back!! Step with the big boys. (IMG:style_emoticons/default/thumb3d.gif) |
Chris Pincetich |
Oct 19 2006, 06:24 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Under the trunk floor is an extra metal flap for a muffler sound barrier that can be removed. If you cut the trunk floor out, don't cut the tranny mounts out too! Good discussion about tranny mounts/body actually flexing under high Gs in the Paddock. With a cage, you can cut out most of the dash and seat/floor cross members. Once you have spent 10 hours doing this, you could have shaved off the same or more weight in 10 minutes changing the lids to fiberglass. That's my plan, the rear was fitted last night...GT Racing looks good so far. Also, I lost about 6-8 lbs with new modern tranny mounts from WEVO and the mini-starter from eBay. (IMG:style_emoticons/default/beerchug.gif)
Bleyseng |
Oct 19 2006, 06:32 PM
vincesix |
Oct 19 2006, 09:37 PM
Streetable or raceing only? for the street fiberglass front and rear trunks saves alot of weight as do bumpers. |
jd74914 |
Oct 19 2006, 09:49 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Nope . . . do both of those things. The sounddeadening, tar, and door guts weight alot.
Jeroen |
Oct 20 2006, 09:21 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
don't hold back (IMG:style_emoticons/default/wink.gif)
(IMG:http://www.914world.com/bbs2/uploads/blog-1132592788.jpg) |
J P Stein |
Oct 21 2006, 10:19 PM
73 was the change over year for safety beams in the doors....meaning you may have either. My 74 doors weighed 64 lbs each. The early gutted doors weigh20 lbs.
88 lbs loss for free is a gud price....just don't get T-boned. (IMG:style_emoticons/default/biggrin.gif) Attached thumbnail(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 05:30 PM |
