GWN7 |
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region ![]() |
My new work ride. Built by E-One in Florida Has all the goodies. Bostic air ride seat, Michellins, cold weather package, air and dual air horns mounted in the bumper. dual action steering, 75' ladder, 1000 gpm pump. 10,000 Watt built in generator with pole lights. Goes around corners like a 11' tall truck, almost 40' long. The only complaint is it doesn't like to back up an incline with fresh powder snow. Cost $500,000 US
It may not be a Auto X contender, but it can go thru red lights and photo radar easily. Makes rush hour traffic a breese. Duh...forgot the picture....... |
GWN7 |
Picture (IMG:style_emoticons/default/laugh.gif)
Attached image(s) ![]() |
Curvie Roadlover |
Two trunks are better than one! ![]() ![]() ![]() ![]() Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 ![]() |
Diesel?
GWN7 |
Yep, 450hp Cummins
Went on a call today and found these on the floor afterwards. The nut part was beside the drives side front tire and the head was 30' away sitting on the stairs going up to the second floor. Washer was laying under the truck Came from the steering box. Attached image(s) ![]() |
Hawktel |
Senior Member ![]() ![]() ![]() Group: Members Posts: 818 Joined: 2-April 03 From: Ogden Utah Member No.: 506 ![]() |
Fire Trucks are cool.
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Man. That is cool. One day I want to ride in a fire truck.
Is it all wheel drive ?? B |
GWN7 |
Nope rear wheel drive only. Same drive train as a Kenworth.
We are getting a specialty unit in 2 weeks built on a F350 4 X 4 frame. It mainly for grass/brush fires, so we can drive and put them out at the same time. Some departments have a "ride along" policys. You have to sign a waver, but get to go to a few calls. |
Hawktel |
That one got a Kramer chair to steer the back? Do you get to Drive the Kramer chair if it does?
GWN7 |
No "Kramer" chair. Those are on tiller units, usually they are 125' ladders and found in areas that have old narrow streets. You steer them in the opposite direction from the front wheels. If your going right the back end is steered left to swing it out and then turned to the right. Fast wheel spinning required. NYC has them & so does Chicago.
Lo-Fi Version | Time is now: 12th July 2025 - 07:11 AM |
