Replacement fuse box, Would you buy one? |
3d914 |
Nov 8 2003, 08:19 AM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
This is something I would put near the top of my list.
In fact, for the first time I knocked out two fuses getting in the other day - and that's with an 8.5 shoe size. I guess you've surmized that I have my cover in the glove box also. Gets my vote! |
JWest |
Nov 16 2003, 04:34 PM
redshift |
Nov 16 2003, 04:37 PM
Awesome James!
(IMG:style_emoticons/default/smilie_pokal.gif) Once again, a nice addition to the parts pile. Much more positive connection with those. M |
914werke |
Nov 16 2003, 05:17 PM
"I got blisters on me fingers" Group: Members Posts: 10,115 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
SA..weet (IMG:style_emoticons/default/smilie_pokal.gif)
Thats a definite do-er! Tell us more about your Speaker box setup..seems very clean? |
swood |
Nov 16 2003, 05:18 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Very COol James! Is it a relatively direct swap over for the wiring?
(IMG:style_emoticons/default/clap56.gif) |
JWest |
Nov 16 2003, 05:51 PM
The speaker is just a Clarion 5x7 plate (SRC5794) with the edge trimmed down. The holes actually line up with the factory speaker mounts.
No wires are cut or modified to do the install - you could return it to the original fuse box and the only telltale would be two new holes in that black plate (screws on the ends of the new fuse box). The original wiring diagram still applies - I wanted to keep the same fuses for the same outputs (most people have a hard enough time with wiring without changing it around!) The only difference is that there are 3 extra fuses - but those are just there if you want to use them. It's almost the same as replacing the original fuse box, one wire off at a time and onto the same position on the new one. I have internally bussed some fuses together just like the original, so no changes there either. It will take a bit to gather all the parts in bulk, but the ball is rolling now. |
pjhaun |
Nov 16 2003, 11:58 PM
Member Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None |
Take a look at this:
http://www.jcwhitney.com/webapp/wcs/stores...1&storeId=10101 |
Brad Roberts |
Nov 17 2003, 01:42 AM
Brad Roberts |
Nov 17 2003, 01:44 AM
Hey.. I knew JC Whitney was good for something. Looks like you may have found a cheap source for James.
B |
914Timo |
Nov 17 2003, 07:10 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
914Timo |
Nov 17 2003, 07:38 AM
Engman |
Nov 17 2003, 07:49 AM
Zoisite Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
Nice - but $130 is too much for just a fuse block. Heck you can do the same thing with (2) 6 ATO fuse holders for about $26.00 - I have to post a link to it later - I have it bookmarked at home.
M |
JWest |
Nov 17 2003, 08:39 AM
QUOTE(Engman @ Nov 17 2003, 05:49 AM) Nice - but $130 is too much for just a fuse block. Heck you can do the same thing with (2) 6 ATO fuse holders for about $26.00 - I have to post a link to it later - I have it bookmarked at home. M Thanks for the comment, and you are correct, if you have the ability to do it yourself then you certainly can pretty inexpensively. I hope my pics will give you some ideas of how or how not to approach it yourself. What I am trying to provide is something that will install with almost no mods to the car (people tend to be averse to cutting the harness and making holes) AND comes with instructions and fuse labels so the person scared of the electrical system (most who work on cars it seems) can do this and more easily troubleshoot in the future. |
Nov 17 2003, 10:53 AM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I'd buy one pretty quickly. Installation, welllll.... We know how quickly stuff gets done on my 914, right?
I've looked around to try to find modern fuse panels that fit the original location, and I could not. In fact, the closest I could find was a six-fuse panel that filled about 3/4 of the available space. $130 is a bit steep for something you can make yourself for under $40, but I'd still pay it. Seems to be a decent price point, actually. Most especially for a plug-and-play setup--that's worth quite a lot right there!! --DD |
Qarl |
Nov 17 2003, 11:03 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
The Hella fuse panels are also available from PepBoys
http://www.7453217467431.com/browse/assBro...fID&affID=39901 |
JWest |
Nov 17 2003, 11:46 AM
QUOTE(Dave_Darling @ Nov 17 2003, 08:53 AM) $130 is a bit steep for something you can make yourself for under $40, but I'd still pay it. I know it seems expensive to the do-it-yourselfer at first glance, but there really is more than just mounting up some fuse boxes and plugging wires (that's what the end user of this design gets to do, though). I have not found any of the cheaper boxes mentioned to fit in the available space with at least 12 fuses. There are also other concerns such as the ability to cleanly buss the fuses together without adding more complexity to the wire bundle. There are mounting brackets, labels, fasteners, wire, and connectors that go into this, and because I know I won't sell a million, the parts add up quick. I have done all the research to insure that the fuses are properly labeled (the '76 owners manual I have is incorrect in that it lists the fused items as in '72 and earlier cars) with the wire colors shown for easy troubleshooting. Anyway, I know this is not a product for everyone, but I think it is a good product that some will appreciate. |
Qarl |
Nov 17 2003, 12:23 PM
Yes... James is right. To you really want to "experiment" and run the chance of frying your wiring?
Plug and play is much better than plug and pray! |
seanery |
Nov 17 2003, 03:45 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I would buy one for my "winter" list of things to do.
AZ914 |
Nov 17 2003, 05:41 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
Yeah, I've thrown the shoe into that damn panel multiple times.... in the dark too. Yeah, my cover now lives in the center console tray for some reason. I don't know what a good price would be but I would like a better setup.
Nice work James, thanks for the info. |
Engman |
Nov 17 2003, 05:49 PM
Lo-Fi Version | Time is now: 31st May 2024 - 07:46 PM |
