Splitter, they sell these at Home Depot now... |
Trekkor |
Nov 13 2006, 11:52 AM
Honestly, the early Sweeper Damâ„¢ would pop Dzus faseners all the time.
With the brackets and increased rigidity of the whole device, it takes a bit of work to get it on or off the car. KT |
URY914 |
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,426 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I guess I'm failing to see how I am going to strengthen anything made of fiberglass by the fastener choice I make. I'm not searching for front downforce as much as I'm limiting air from going under the car and forcing air into my cooling ducts. I eliminated the rear end float and have a greater confidence driving at speed due to increased car stability. That was my goal and this is was I achieved. KT Mission accomplished (IMG:style_emoticons/default/smile.gif) |
Trekkor |
Nov 20 2006, 07:24 PM
Update:
Gallery More shots from David Wong that I am purchasing. (IMG:style_emoticons/default/clap56.gif) KT |
grantsfo |
Nov 20 2006, 09:56 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Update: Gallery More shots from David Wong that I am purchasing. (IMG:style_emoticons/default/clap56.gif) KT (IMG:style_emoticons/default/clap56.gif) |
nebreitling |
Nov 20 2006, 09:58 PM
those pics are beautiful. car looks great, trekkor.
maf914 |
Nov 21 2006, 03:01 PM
Trekkor,
Looking good. What kind of wheels are those? What happened to your widened red steelies? |
Trekkor |
Nov 21 2006, 03:46 PM
The wheels in these shots are the ones I got from Nate.
6.5" 3 piece rims. I think he called them "Epsiloms"? Hoosiers mounted. The red wide steelies ( 7" ) are currently my a/x rims. 710's mounted. With the the splitter mounted the car feels "planted". Seem more stable to me. I do know that I found myself with more speed than normal as I approached turn 10 at Sears. may be due to the ability of the car to carry and build more speed through the esses from turn 7( ? ). KT |
DanT |
Nov 21 2006, 03:53 PM
The wheels in these shots are the ones I got from Nate. 6.5" 3 piece rims. I think he called them "Epsiloms"? Hoosiers mounted. The red wide steelies ( 7" ) are currently my a/x rims. 710's mounted. With the the splitter mounted the car feels "planted". Seem more stable to me. I do know that I found myself with more speed than normal as I approached turn 10 at Sears. may be due to the ability of the car to carry and build more speed through the esses from turn 7( ? ). KT your increased speed probably has more to do with becoming more comfortable with your car at speed and refining your driving lines. Not to mention getting enough seat time to increase your overall abilities.. (IMG:style_emoticons/default/smile.gif) And besides you are now using a different wheel/tire combo than before...don't you think that might have something to do with your increased speeds? (IMG:style_emoticons/default/smile.gif) |
kart54 |
Nov 21 2006, 03:56 PM
Senior Member Group: Members Posts: 544 Joined: 27-January 05 From: Ventura, California Member No.: 3,520 |
Trekkor,
Car looks great. Has the splitter affected your engine temps at all? If so, negative or positive? Randy |
Trekkor |
Nov 21 2006, 04:40 PM
QUOTE more comfortable... refining your driving lines... seat time... different wheel/tire combo yes, I'm sure that is also a factor. it all adds up. your instruction was the turning point for me, you should know. (IMG:style_emoticons/default/clap56.gif) QUOTE Car looks great. Has the splitter affected your engine temps at all? thanks!! Engines temps on moderste days are staying below 210 after the longest of sessions. I haven't had a chance to run the splitter in the summer yet. It's been on the car for a total of 4 track hours, now. KT |
DanT |
Nov 21 2006, 04:48 PM
QUOTE more comfortable... refining your driving lines... seat time... different wheel/tire combo yes, I'm sure that is also a factor. it all adds up. your instruction was the turning point for me, you should know. (IMG:style_emoticons/default/clap56.gif) QUOTE Car looks great. Has the splitter affected your engine temps at all? thanks!! Engines temps on moderste days are staying below 210 after the longest of sessions. I haven't had a chance to run the splitter in the summer yet. It's been on the car for a total of 4 track hours, now. KT Thanks Trek,,,,and I don't think the splitter looks like it is unsafe in any way, especially with the turn buckles you have giving it more strength in a verticle dimension. |
Trekkor |
Nov 21 2006, 04:59 PM
I like the fact that it is REAL STRONG.
i like bouncing the berms and I feel confident that it will not break in half or worse. After 1.5 hours of Sears, all i have to show is a few half worn down bolt heads and a little blue and yellow paint. the steepest slope on that track is the entryway to the pit lane between the two garages. (IMG:style_emoticons/default/ohmy.gif) KT |
Randal |
Nov 21 2006, 05:07 PM
QUOTE more comfortable... refining your driving lines... seat time... different wheel/tire combo yes, I'm sure that is also a factor. it all adds up. your instruction was the turning point for me, you should know. (IMG:style_emoticons/default/clap56.gif) QUOTE Car looks great. Has the splitter affected your engine temps at all? thanks!! Engines temps on moderste days are staying below 210 after the longest of sessions. I haven't had a chance to run the splitter in the summer yet. It's been on the car for a total of 4 track hours, now. KT Thanks Trek,,,,and I don't think the splitter looks like it is unsafe in any way, especially with the turn buckles you have giving it more strength in a verticle dimension. The car does look good. Now you need to drop some weight off and get down into the 1:50's; unless you just want to keep it as a driver and stay away from the "Dark Side." (IMG:style_emoticons/default/smile.gif) Did you get a ride with Mike? |
race914 |
Nov 21 2006, 05:18 PM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
Somewhere earlier in this thread someone mentioned that reducing airflow under the car may affect engine cooling. I think the last question was inquiring if "with the splitter you are seeing lower, the same, or higher temps under the same conditions?"... i.e. on moderate days did you run under 210 before adding the splitter?
Trekkor |
Nov 21 2006, 05:26 PM
I didn't take any rides that day.
Mike "who"? |
Trekkor |
Nov 21 2006, 05:31 PM
As for temps. i do not detect any changes. Seems to be the same.
KT |
race914 |
Nov 21 2006, 05:35 PM
Randal |
Nov 21 2006, 06:06 PM
Trekkor |
Dec 11 2006, 01:28 PM
Entry to 14 at TH.
KT Attached image(s) |
Joe Ricard |
Dec 11 2006, 02:41 PM
Seems the front splitter is having an effect on your front suspension. you seem to have lots of forward rake to the car.
I am working on a front splitter also. and already mounted a REAL wing on the rear deck lid. Just curious about how much of a blade do I really need to have sticking out. |
Lo-Fi Version | Time is now: 7th May 2024 - 08:38 AM |
