Retrofitting 1976 with early front bumper. |
dhopkins |
Oct 27 2006, 08:36 PM
Member Group: Members Posts: 50 Joined: 7-July 04 From: Rydal, Pa Member No.: 2,315 |
Is it possible to install an early bumper on a 1976? If so how is it done?
Don 0----------------------------------------------------- 1976 914 2.0 1969 911S 1981 911SC |
boxstr |
Oct 27 2006, 08:54 PM
Yes it can be done. You might try a search for the subject it has been a thread recently.
If you don't find it I will give you some help a little later tonight. Craig |
porschecb |
Oct 27 2006, 09:10 PM
Senior Member Group: Members Posts: 1,092 Joined: 13-August 04 From: Las Vegas NV Member No.: 2,529 Region Association: None |
what! you don't like late style bumbers! There faster than the older style (on the track) !!! (IMG:style_emoticons/default/biggrin.gif)
So.Cal.914 |
Oct 27 2006, 09:19 PM
The condom bumpers are heavier. There are four bolts that hold the old style
bumpers on, two on each side. Get your measurements from an old tub for those holes and drill them into yours. Measure twice drill once. Oh and you will need the bones. |
Oct 27 2006, 09:23 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I believe Paul means "rubber dog-bones", which go between the metal bumper and the car's body.
You also need to grind off the tabs on the side of the car that hold the ends of the bumper cover, and shorten the front lip of the front trunk's seal channel. That serves as a lip to hold the top of the bumper cover. Remember to paint any bare metal... --DD |
dhopkins |
Oct 27 2006, 10:06 PM
I searched but found not a single thing. If I change to the early
bumper will it hurt or help the car's value? Don ___________________________________________ 1969 911S 1976 914 2.0 1981 911SC |
jk76.914 |
I did it on my '76. I think it was worth it.
I found the front bumpers in good shape to be much harder to locate than the rear ones. Mine isn't perfect, but its better than most, and most people don't notice. After you pull the bumpers and bumper shocks, you have to remove the tabs on the sides where the ends of the rubber cover used to hook. Then you fill the big holes that the shocks used to go through. Also, the thin metal tab that runs along the front edge of the trunk openning isn't needed anymore either. I is supposed to hold the top edge of the rubber cover down and in place. I think it was spot welded inplace and can be removed by drilling the spot welds out. Finally, you drill new holes for the dogbone bumper brackets. I found this to be the trickiest part, because there isn't much room left and right for the bumper to sit off center, muchless look right. On the original cars, there were L brackets welded in to reinforce the bumper mount to the side rail of the unit body. These are in the wheel well. I did not put anything in there, so my bumper and front panel would probably cave in an accident before the side rail. Maybe someday I'll have something welded in, I don't know. It's easy enough to do when ever I get the motivation. In the back, you'll also need new license plate lights- the early ones are different. Also, there's a steel tab from the body, directly above the license plate, that the center stud from the rubber cover goes through.... another tricky part, getting it the right height and centered.... Good luck! Jim Some pictures- the back is a similar process. started with this big shock holes to be filled.... shock holes filled, attachment holes drilled, everything primed fuzzy pic, but the tab is there below the lock hole today! TA DA! |
boxstr |
Oct 27 2006, 10:34 PM
Well It looks like most of the process has been covered.
The major part of this process is the purchase of good front and rear bumpers. You will need the dogbones , you will also need good rubber bumper tops. One thing that I always do is use threaded studs instead of bolts. You put the studs in where the bolts are supposed to go and you can slide the dogbones over the studs, and slide them into the holes that you have drilled for them. This makes it a one person operation. Note: you will use the dogbones for measuring the distance for the holes you will need to drill in the front and rear. I will add a couple of pics for reference. I have done about 20 different bumpers backdates, It is really very easy. CCL Attached image(s) |
boxstr |
Oct 27 2006, 10:35 PM
A few more pics.
boxstr |
Oct 27 2006, 10:37 PM
Last one....
Bleyseng |
Oct 27 2006, 11:18 PM
Nice pics Craig!
yep. its fairly easy to do and worth it. Attached thumbnail(s) |
So.Cal.914 |
Oct 27 2006, 11:45 PM
The studs in the bumper are a great idea Craig.
jk76.914 nice job on your 76. |
dhopkins |
Oct 28 2006, 11:17 AM
Thanks very much. Great job! How about the rear bumper? Anybody know how that is done?
Allan |
Oct 28 2006, 11:42 AM
Thanks very much. Great job! How about the rear bumper? Anybody know how that is done? Pretty much the same way the front is done except you only have to trim the brackets on the left and right sides. Also, get Engmans cover plates for the front shock holes or you'll fill the front trunk with water everytime you was the car... |
jk76.914 |
Oct 28 2006, 02:35 PM
Thanks very much. Great job! How about the rear bumper? Anybody know how that is done? Also the tab over the license plate. It'd be tempting to leave it off, but I wouldn't. Otherwise the rubber top is self-supporting in the center. Take another look at my earlier post.... I have a fuzzy pic of the tab. Jim |
shelby/914 |
Oct 28 2006, 04:36 PM
Senior Member Group: Members Posts: 804 Joined: 24-August 05 From: Foxfield, Co Member No.: 4,655 Region Association: Rocky Mountains |
There is another very good thread from Jan 04 entitled Old School Bumpers, retrofitting to a 76, but I could not get the search function to go straight to it. Found it by searching bumper conversion which came up with 23 pages. On page 21 there is a post called bumper backdate. There is a link in it which goes to old school. Good Luck. It should be easier but, (IMG:style_emoticons/default/WTF.gif)
Lo-Fi Version | Time is now: 14th May 2024 - 02:56 AM |
