Source for switched power ..., for fuel pump (carbs) |
Eddie914 |
Nov 3 2006, 08:58 PM
Unregistered |
The fuel pump (early 911 Hardi internally regulated) on my '71 3.2 conversion with 40mm webers is in the front trunk with wiring running off the original wiring in the engine compartment. After having fuel pump problems at the track last weekend, I would like to simplify the wiring for the fuel pump and just run power from the fuse panel to the pump. What would be a good source for switched power? Is a relay needed for the fuel pump on a carbed engine? Thanks Eddie |
Lo-Fi Version | Time is now: 23rd May 2024 - 09:48 PM |
