buggered up the qt panel a while back, dent |
bd1308 |
Nov 5 2006, 01:21 AM
kidna hard to explain, a combo of a floor jack and not good chocks and soft asphalt during summer caused the car to fall off the jack and onto the tire/rotor as i was putting tire on car.
I'm ok, but the car's fender is pushed up and out a tad. peen hammers, or a section from a donor? |
So.Cal.914 |
Nov 5 2006, 01:41 AM
Could you post a few pic's?
bd1308 |
Nov 5 2006, 01:44 AM
If I get a chance I will.
jsteele22 |
Nov 5 2006, 01:14 PM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
Just tagging along with this one - I've got a damaged LR 1/4 panel. I'm guessing a skilled body shop could pound it out, but wondering if replacement is a DIY option. Is replacement something a newbie can approach, or is it a "experts only" kind of job ? |
So.Cal.914 |
Nov 5 2006, 01:43 PM
If you can opperate a drill a saw a grinder and you can weld I don't see any
reason that you couldn't do it. Just take your time |
bd1308 |
Nov 5 2006, 02:34 PM
well this guy has a stud welder, and a puller for it.
I think i'll just do what I need to do. This car is already three different cars welded together, I doubt i'm compromising value by fixing this |
thewheel69 |
Nov 5 2006, 02:43 PM
Wazabi 1.8 Group: Members Posts: 54 Joined: 14-December 05 From: Fort Collins Member No.: 5,275 Region Association: Rocky Mountains |
I'm tagging this thread too... same issue with a Left Rear I need to figure out...
bd1308 |
Nov 5 2006, 02:44 PM
Give me a week, I'll pull it and let you know how I did it.
bd1308 |
Nov 5 2006, 02:45 PM
I welded my car back together again (massive hell hole rot) and I am not a expert.
Lo-Fi Version | Time is now: 18th May 2024 - 02:50 AM |
