Alignment, done ! |
Alignment, done ! |
J P Stein |
Mar 6 2003, 03:19 PM
Hey, we went out in the rain today.
Fortunately the alignment chop is only a half mile away. Here's what we gots: Camber R/F -1.99 L/F -1.99 R/R -2.3 L/R -2.25 Caster R/F 5.08 L/F 5.31 1/16 toe in at both ends. Pulled another 3mm shim from each side in the rear. I"d like to get more caster, but I'd have to do some more grinding around the strut mounts. Maybe next winter. A short drive shows the car to be VERY responsive. The ride is....er....firm....but not as bad as I thought it would be. Vracers really suck in the wet. Now if the weather would cooperate, we can go play Sunday. It ain't lookin' good, tho. |
Jeroen |
Mar 7 2003, 05:54 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
QUOTE(J P Stein @ Mar 7 2003, 04:29 AM) Cause I screwed up (thanx for asking). I forgot what Tony told me for the front. So we decided on 1/16 in. Ok, that's better... You had me worried for a minute there that you did that on purpose (IMG:style_emoticons/default/biggrin.gif) On my 911 (yeah, I know, different cookie) I've got zero toe front and rear Turn in is great with the zero toe front. On not too smooth roads it needs your attention over 120mph, but nothing to get nervous about. I hadn't really looked into the toe settings for the rear, so I decided to go zero there as well as a starting/reference point. I really like it. It makes the car feel very neutral on the track (as far as a 911 can ever be neutral) and both under and oversteer are easily found/corrected. (nothing is more fun that 4 wheel slides (IMG:style_emoticons/default/mueba.gif) ) For an AX-only-car you might even wanna try a little toe-out cheers, Jeroen ps I can't believe I actually used that stoopid banana (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 01:35 AM |
